My surronds speaker getting prot off, when i increase volume
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
If you're saying that the unit is going into PROTECT mode when you turn up the volume, check to see if you have all the speakers hooked up correctly, no strands of wire between the + and - terminals. Make sure that you're using speakers rated at 4 - 8 ohms. If all that is correct, you may have an amplifier bad. For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Nov 28, 2013
How do I increase the volume on the speaker?
Search Results
    How to improve sound quality and increase volume on ...
    https://www.androidpit.com/improve-the-sound-and-volume-quality-on-...
    Dec 4, 2015 - Not all smartphones are blessed with speaker quality or volume levels to make your stereo envious. ... How do you improve sound quality on your phone? ....I've seen a 'little' cellphone case, foam padded with a zipper, that ...
    How to increse speaker volume on android smartphone
    www.instructables.com/.../How-to-increse-speaker-volume-o...
    InstructablesRequirements:You will need a phone with Mediatek chipset. ... is a quick turtorial on how to increase the volume of front-facing speakers on android smartphone.
    Increase your Android Phone's Audio Output with Speaker ...
    www.techverse.net/increase-android-phone-volume-output-speaker-boost/
Jan 27, 2016 | Cell Phones
How to increase speaker volume
There is a volume button on the phone to increase(up arrow) and to decrease(down arrow). Keep pressing the up arrow to increase the volume till you can hear clearly either with speaker or without speaker.
Sep 13, 2014 | Lands Phones
Hello ! I have a Sony DAV-DZ640K Home Theater System, the problem is that I can increase and decrease sound levels for individual speakers, like i am able to increase and decrease surround (back) speakers...
Sound distribution varies according to speaker configuration. You have to select speaker size and placement and a number of other characteristics to get results. A review of the setup instructions in accordance with the physical size of the speakers you are using and nominal impedance values may help.
Feb 26, 2014 | Sony Audio Players & Recorders
Increase speaker volume in laptop
Easy and best way to increase the laptop speaker volume is to install VLC media player. you can increase the speaker volume by 400%.
Dec 18, 2012 | Dell Inspiron 1525 Notebook
SYSTEM SHOWS ERROR CODE PROT AND SHUTS DOWN
Check the impedance (resistance) on all the speakers and the speaker wires themselves.
Power up the unit with no speakers or inputs attached at minimum volume and see if it still goes into protection mode.
Most speakers should measure between 4 and 8 ohms for most systems when disconnected from the receiver.
If the unit says PROT even with no inputs at minimum volume with the speakers detached, then there's a problem with the amplifier itself, probably in the output section.
Jun 12, 2011 | Samsung 1000W 5.1-Ch. Home Theater System...
Not all the speakers working
Open your audio control panel and set it to 5.1 surrond sound. Not all speakers will work unless a dolby surrond sound signal is being sent out. There will be a pseudo surrond setting which will emulate the 5.1 for you in the audio control panel
Mar 03, 2011 | Logitech X-530 Computer Speakers
I have surrond sound speakers thats loud but wend
I had an issue like that with one of my dell desktops too. The speakers were very quiet. I turned up the volume on the speakers, turned up the volume in windows. Unisntalled and Reinstalled audio drivers, I eventually assumed that the speakers were just junk. After buying a soundcard (I was originally using onboard sound), I discovered that the speakers were much louder through the soundcard than through the onboard audio.
Feb 28, 2011 | Dell Computers & Internet
When i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
PROT means that the AMP is protecting itself from damage due to bad or incorrect wiring or damaged and or incorrect speakers. Check your wiring and speakers.
If you find no problem then, DISCONNECT YOUR SYSTEM FROM THE POWER, disconnect your speaker wires...all of them, then reconnect the power ONLY, turn on the system and see if it still says PROT. If it does then your amp is damaged.
Feb 20, 2011 | Samsung HTC550 Theater System
How do I adjust each speakers volume?
You could start with the manual which is available at retrevo.com for free.
Speaker settings are primary to the quality and effects you hear. Surround modes depend on them.
The factory defaults assume you're in the center of a perfect circle of speakers (page 21). You need to adjust the delays of the Center and Surrounds to delay them so their sound arrives at the same time as the main speakers.
Page 27 deals specifically with relative speaker levels. You want to have the subjective sound level at your primary listening position be the same from all speakers with the test tone. I would recommend that you figure out which one(s) are the loudest at 0dB and adjust the rest to it(them).
Apr 07, 2010 | Audio Players & Recorders
How to increase speaker volume during phone on nokia E63
To adjust the earpiece volume during a phone call,
scroll left or right. To adjust the volume of the media
applications, press and hold the function key, and scroll
up or down.
Dec 05, 2009 | Nokia E63 Cell Phone
16 people viewed this question
 Grubhead
Grubhead
