Question about Maytag SOV110RC/B Dual Fuel (Electric and Gas) Kitchen Range
Cooker knobs hob - Maytag SOV110RC/B Dual Fuel (Electric and Gas) Kitchen Range
2 Suggested Answers
  • 1462 Answers
SOURCE: Cooker auto spark will not
many hobs have a thermocouple which is like a small rod sticking up into the flame. when this is heated up, it holds the gas valve in. if the thermocouple has failed the gas valve will release as soon as you let go of the knob. only solution is to replace the thermocouples
Posted on Jun 26, 2008
I need a Manuel for my Russel Hobs Slow Cooker 13792
Instructions for slow cookers are fairly generic.
I assume your control knob says "OFF", "LOW, "MED" and "HIGH".
If I were you I would just google recipes for crock pots.
Feb 02, 2015 | Crock Pots & Slow Cookers
How to lift a2 smeg cooker hob
remove cast iron pot stands and pull off all knobs and small timer buttons. lower the oven doors and look up under the panel holding the knobs and you'll see a screw at each end, remove them. you can now remove the stainless switch panel, (swing the bottom out first) you can now get access to screws at each top corner which should be removed. you can now lift the top panel of the cooker by about 5 inches when a pivoted stay should drop down each side to allow you to rest the top in an open position.
Oct 13, 2012 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Please can anyone help? We are in a rented property and we have an NEB Venezia SS electric oven with gas hob and all the writing on the knobs has been erased over the years. The hob works fine we need to...
Look up the oven on the web the knobs vari in calabration figures so I have never worked on this model, try a search engine you may find a showroom near you pop in and have a look.
hope this has been helpful
John
May 31, 2011 | Ovens
Gas hob is very difficult to start. have to hold
I've just had this prob on an inherited (just moved into new house) A2. Thought I was losing the plot as followed instructions to the letter re starting gas hobs. Got an engineer in to give the ecking thing a general service & told him about the hob. He said I wasn't pressing the knob hard enough. If you press the knob enough to make the ignition click, press the knob a bit further (it will go a bit further "in" honest). If you do that it should start like a good 'un (I felt sooo daft). Something to do with magnets!! Anyway, give it a try (this works for me unfortunately I've had the damn inner glass on the main oven go pop - yes, infront of an engineer twice in less than ten days. Knobs aside, I'm starting to go off this cooker. I want to cook to eat not have a "pretty" in the kitchen!).
Apr 12, 2009 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Jan 09, 2009 | Cooktops
Cooker auto spark will not light two hobs. There is a spark and the hobs flame but on relaesing the knob they go out. Conitueing this for say 5 mins does no work either.
Jun 26, 2008 | Maytag Kitchen Ranges
Maytag SOV110RC/B Dual Fuel (Electric and Gas) Kitchen Range Logo
20 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
