Dear Electronic Repairer, 1-Plasma TV Troubleshooting sharp model 32SA1E when I turn on, it no show display, no sound... But before it worked 5 a 10 min and turn off alone? Please help ------------------------------------ 2-TV philips mod: 42PF3320 no sound, no picture and menus is active Dear Electronic Repairer, Good evening friends of the art I have a philips PLASMA TV mod; 42PF3320 with the following defects; The TV is on stand by when plugged in energy. Load when the Power button (red light. STBy is) blinking, no change to the green (normal operation) does not appear nothing on the screen or the sound or the image to the screen so dark. However there is the Menu-v + ve numbers of active channels on the screen when these botons. must resolve this problem in TV. Can you help me? All the voltage on te power suplly is all ok! I look at .. any hint is welcome. greetings
  • 400 Answers
Through remote set its brigtness
Posted on May 31, 2009
Samsung Plasma TV just died, some troubleshooting done already. Model Number PS64F8500
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 21, 2016 | Samsung Pn64d8000 64-inch 1080p 600hz 3d...
Maxent 42' plasma
All electronic devices emit an electronic noise. Depending on the amount of electrical current running through the device there can be an increase in the amount of noise emitted.
There are 2 PC boards on the right and left in the back of the Plasma TV. These 2 boards connect to the plasma display panel and are responsible for providing the electricity to light the individual cells on the plasma. Each of these boards is connected directly to the main power supply of the unit. When there is a bright scene, these boards have a great deal of electricity flowing through them. Under this circumstance, you may detect a small amount of electronic noise. This is because the power supply is working harder delivering the amount of power necessary to these boards. The electronic noise you are hearing is actually coming from the power supply. When the scene displayed is dark, there will not as much.
If the screen is next to the wall, some of that noise will be reflected out into the listening area. It the environment the plasma is in an echo-rich environment, this may also cause the electronic sound to be more apparent.
Each of these screens has been tested and is within the sound levels listed by the manufacturer (under 40db). This value is the same for nearly all plasma manufacturers.
This type of electronic sound is completely normal and is not serviceable.
the problem is the power supply check it.
Sergio
Mar 21, 2008 | Televison & Video
Maxent plasma tv no picture or sound
Check and replace that board. Just visit the site linked here. Y Sustain board faults and symptoms of plasma display is given in details. http://electronicshelponline.blogspot.com/
Apr 07, 2017 | Maxent MX-42XM11 Television
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
PIONEER PDP-R06U / PRO-R06U MEDIA RECEIVER SERVICE
Hey,
This may be too late...
I got it from the field manual.
Trap Switch Reset Procedure
G-4, G-5, G-6, G-7, G-8
• Replace media receiver, plasma panel cover, or tape down HDCP trap switch.
If the model in question has the TV Guide option, the TV Guide
option must be turned off before proceeding.
• Using the customer’s remote control enter “service mode” by pressing the
following key sequence:
1. Press the “display” button then release the “display” button.
2. Wait between 3 and 7 seconds
3. Press and release the “<”, “^”, “<”, “>”, and “power” buttons in sequence.
• Panel will now turn on in “service mode”.
4. Press “muting” button 3, 4 or 5 times depending on model you are working on.
Until the display shows the “initialize” page.
5. Press and hold the “display” button until the error indicator (red LED) on
either the panel or the media receiver goes out.
6. Exit service mode by pressing the “power” button on the remote.
I had to try it a couple of times before I got it to work. I.m not too sure how to turn off the tv guide mode. I just held it in for a couple of sec,s.
Good luck
Dec 05, 2009 | Pioneer Audio Players & Recorders
Cable/Analog Icon on screen
Usually the DISPLAY Button on your TV remote will toggle through several different functions: 1 sec, 5 sec, Always on..... Press button until display on TV is off. Or see if there is an ON SCREEN DISPLAY portion in the TV Menu and turn it to off if you have not checked that already.
Apr 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv troubleshooting
There is problem in the power Supply section.check the h-out Transistor if Damage then Change for the Same COde #
Nov 13, 2008 | Televison & Video
I heard a loud pop sound and my 48 zenith plasma tv picture went black. Even the words "video 1" don't show up when selected. It's getting power; The green/red light is on. I've checked all the...
Does anything come on the screen? Input display box?
If no:
Sounds like it could be a blow capacitor. Cheap part, but need someone with a little electronic know how repair to fix it.
Mar 14, 2008 | Zenith P42W22B/H 42 in. Plasma Television
The green light on for 2 seconds and off again (Panasonic TH-42PWD5UY)!
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Jan 23, 2008 | Panasonic TH-42PWD5UY 42 in. Television
Open Questions:
Computers & Internet Logo
366 people viewed this question
David Payne
David Payne
