Question about Garden
Engine runs but no power to the head
I was running my string trimmer with the tiller attachment. the trimmer shaft got really hot and stopped working. I removed the attachment and could smell hot grease. My trimmer is about 2-1/2 years old. Is it time to replace or is there a simple solution? RYOBI SS30
    President:
  • 1,489 Answers
It could be simple. Sounds like the drive cable came loose or broke. You could get an estimate from a repair shop -- probably not terribly expensive.
Posted on May 08, 2009
I have a Poulan PP025. It runs fine; good acceleration and idle, several hours of great cutting; then the weed-eater suddenly ran as if out of balance, the head then stopped spinning. Any ideas?
curved shaft trimmers use a flex drive in side the case so that it can drive around the bend of the case
they are held in line with bushes spaced along the tube and this prevents the flex drive from binding back over itself
from your description of the problem, pull that flex drive out of the case and check for signs that it has a problem
the problem with bent shafts is that they will not handle any sort of a load and therefor are not suitable for heavy growth, heavy trimmer line or any metal/fixed attachments
the heat in the case will be from the flex drive rubbing on the inside of the case
Jun 06, 2016 | Poulan Pro PP025 17-Inch 25cc 2-Cycle...
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Motor starts and runs fine but trimmer heads only spins slowly
replace the centrifugal clutch at the motor end of the unit shaft
Jul 18, 2015 | Troy-Bilt Troybilt Mtd String Trimmer...
Head not spinning shaft cable is.
place a screw driver in the slot the drive goes into and hold the trimmer head feel the head
Aug 16, 2012 | Troy-Bilt Troybilt Mtd String Trimmer...
How do you fit the pto to a merry tiller for a flexible drive shaft saw attachment
flex shaft nits are not made to handle anything other than a string trimmer
May 03, 2012 | Garden
I own a Troy-Bilt 425cs string trimmer with multiple add-on attachments. The unit works fine for string trimming, brush cutting, and cultivating. However, it will not properly power my edger attachment. ...
The power edger attatchment may have a slightly different coupling size on it than the other attatchments. Also, do a good inspection of the power head unit's coupling at the EZ LINK connector. Maybe the head unit connector is getting hot over time, due to a lack of lube, and expanding internally, causing slippage in the connection to the edger attatchment. Inspect all that you can.
Sep 11, 2011 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
After using the trimmer for a while it gets hot and then the head stops spinning. It only happens after being used for a while. Took it in but they did not run it long enough for it to happen. It is...
The plastic head is overheating and melting because it is not fit for the work it is doing. When it cools the plastic hardens and it works until it heats again. You need a new head. Stephen.
May 07, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Homelite trimmer runs, but can't run attachments very fast.
Doesn't sound like piston and ring problem. Sounds more like the flex shaft that connects to the engine may have an end that is worn not allowing for the extra load when you connect the attachments. Check the ends of the top flex shaft.
Jun 18, 2009 | Husqvarna 28cc Gas Line Trimmer
Trimmer dust cover hot to touch ... trimmer head flew off and in reinstalling the trimmer does not turn or only turns momentarily before engine shuts off
sounds like the drive cable is jammed.you need to remove the shaft from the engine and head and see if the cable spins freely.
Apr 29, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
31 cc Straight shaft/ head won't turn when connected and running
pull the shat off the engine and check the inner shaft it sounds like its stripped or the theengine side is cracked hope this helps
Oct 22, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
268 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
