Question about Hansgrohe Plumbing
Where do you find this part hansgrohe 95507000
Can't find hansgrohe part 95507000
It took me less then 1 minute to find it after wasting time reading your question. you could also try contacting....ummm...hansgrohe directly...maybe they will have your part since they make your faucet...1-800-344-0455. Do a little searching before posting next time. for further convenience, you can purchase one at this link also.
https://www.guyplumbing.com/index.php/linecards/hansgroheparts/hansgrohe-nylon-spray-hose-5836.html
PS. your searching for the OLD part number. the new one is
97735000
Jan 13, 2014 | Hansgrohe Plumbing
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Hansgrohe shower not hot enough
The first thing to do is identify the unit so I can give accurate instructions. Hansgrohe makes many valves and the temperature adjustment between them is different. Feel free to call me at Hansgrohe at 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'd be happy to help identify the unit and get you the instructions for the temperture adjustment.
Oct 05, 2012 | Hansgrohe Home
Hansgrohe shower head water leaking out of connector
Is it a Grohe or Hansgrohe shower head? If it is a Hansgrohe shower head the first thing to check is if the self sealing filter gasket is installed at the connection to the shower arm. Hansgrohe shower heads have a black self sealing filter gasket in the head that some people remove assuming it is a flow restriction device. It is only a filter and does not restrict flow unless clogged with debris. Next make sure the flow restriction device below the filter gasket is still installed. On some models removing the flow restrictor will cause water to be expressed from the air injection ports near the pivot ball. Feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for Technical and ask for David Scarborough
Aug 20, 2012 | Grohe Home
I need a hansgrohe avate guard lav faucet aerator wrench?
The aerator on Hansgrohe Faucets generally do not require a special tools to remove them. They normally unscrew in a counter clockwise direction. Some specific models do require a tool.Feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech. Ask for David Scarborough.
Jul 04, 2012 | Hansgrohe Plumbing
How do I remove cartridge part # 9273000 from my Hansgrohe kitchen faucet?
Please contact us at the below number or email me directly and I will get you a copy of the instructions that you need.
Regards
Chris
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Email:Christopher.Scott@hansgrohe.com
Feb 19, 2011 | Hansgrohe 06649860 Solaris Single Hole...
Trying to buy 2 replacement heads for my hansgrohe toilet brushes in interactiv pattern
Your part is listed on the USA site; authorized on-line retailers are listed here:
http://www.hansgrohe-usa.com/us_en/131332.htm
If you are not in the USA, you may want to check if Hansgrohe has a website in your country:
http://www.hansgrohe-usa.com/us_en/19254.htm
Trust this is helpful.
Dec 29, 2010 | Hansgrohe Replacement White Head Toilet...
Hansgrohe faucet part-no. 92730000 faucet cartrige installation instructions
Please contact me at the below number or email and I can supply you with a copy of the installation instructions.
Regards,
Chris
Christopher Scott
Hansgrohe Inc.
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Nov 28, 2010 | Hansgrohe 06649860 Solaris Single Hole...
How do I repair a constant drip on Hansgrohe Solarisn?
You will need a replacement cartridge, please give us a call the the below number or email me and we will assist you with this.
Regards
Chris
Christopher Scott
Hansgrohe Inc.
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Oct 21, 2010 | Hansgrohe 06649860 Solaris Single Hole...
Plumbing Logo
57 people viewed this question
Top Hansgrohe Plumbing Experts
Andrew Bugbee
Ian Lulham
Ian Lulham
Level 1 Expert
ray gallant
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
