Question about Refrigerators
Doesn't cool The fan goes on and it starts to cool but then there is a clicking sound and only warm air comes out.
  • Samuel Charles Spriggs May 11, 2010
    I think the clicking sound is the compressor shutting off. How old is the fridge? Has it ever been serviced?
  • 83 Answers
Check your thermostat setting. the clicking sound is probably the compressor un-loading.
If you set the thermostat higher, the compressor will not turn off too soon.
Posted on May 08, 2009
Ge monogram not cooling properly
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 18, 2014 | GE Monogram Side by Side Refrigerator
The unit will come on in house but fan is not on outside you can hear it clicking like its trying to and blowing warm air
Sounds like you need a new Run capacitor or hard start kit (includes the capacitor), but you should have it checked by tech
Aug 21, 2013 | Intertherm Heating Cooling System 15kw...
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Oct 08, 2012 | 2004 Mazda MPV
AC unit outdoor fan motor does not come on as it should, but if I manually start the contactor relay / coil by pressing and holding the manual button on it the fan then comes on and goes off with the...
It sounds like the contacts of the contactor are burnt/pitted. When this occurs, it can allow enough current to operate the fan motor but not enough to operate the compressor.
Apr 07, 2010 | Carrier 38CKC036 Air Conditioner
2002 Dodge Intrepid Radiator Fans Not Working
CHECK YOUR SPEED FAN RELAY ONE SIDE IS FOR YOUR AIR CONDITIONING YOU HAVE HI AND LOW RELAYS
May 23, 2009 | 2002 Dodge Intrepid
Freazer works fridge warm
Hi Jen, I would suspect the thermostat. The fact that the fan is still coming on and off is because it is more than likely getting frozen or clogged with ice making it stop and in turn cooling stops. Yep I would start with changing the thermostat.
Mar 02, 2009 | Refrigerators
My Refrigerator and Freezer is warm
I just had a similar problem, and the bottoms of both sides were cold but the top shelves were warm. I found that the condenser fan, the fan right above the cooling coils was not working. This fan circulates the cold air and if it's not working it can't move the cold air to the top or over to the refrigerator side. Open the freezer door and press the switch that tells the computer the door is closed (so the light goes out), if the fan doesn't come on shortly, or only sputters that could be the problem. You will need to take out the back cover over the coils, the ice maker tray and auger motor if you have one and some other parts. Play around with the plug where it goes into the side wall, if you can get the fan to come on and off, it's most likely a bad fan motor....about $55 to replace. As you take it apart, be sure to take some digital pics of the process so you can remember how it goes back together!
Feb 07, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
