Question about Linksys Wireless-G WRT54GX Router (WRT54GX2)
WRT54GX2 I cannot access the setup utility to add a new mac address.Will I have to reset and start all over?
  • nemoman Nov 08, 2007
    I needed to add a new computer's mac address and could not log onto the unit. Tried connecting wirelessly and directly into one of the 4 wired ports. Ended up reseting the unit.
    President:
  • 2,961 Answers
If you are unable to access the router through the usual ip address you will have to reset the router
Posted on Oct 11, 2007
Need password to my cisco wireless router
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
Oct 17, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I have a router i forget everything to it i cant get into it at all cant access the internet or nothing
To access a router on which you forgotten everything, do the following...
1. apply power to the router and connect an ethernet cable from PC to one of the router's LAN ports
2. press the router's reset button (usually located beside its power supply jack) for at least 5 seconds
3. (pressing reset for 5 seconds resets the router to its factory defaults)
4. with factory defaults, you can now use the Setup Wizard on the router's Setup CD-ROM
5. if no Setup CD or to configure advanced settings see router manual about web-based utility
6. open Internet Explorer and enter the router's default IP address (see router manual for address)
7. IE presents a login window for entry of router userid and password (see manual for defaults)
8. once into the router's Basic Setup screen, follow the steps in the router's manual to do the setup.
9. if your ISP requires a registered MAC address, enter it on the clone MAC address screen
10. for better wireless security, change router SSID from its default and enable WEP or WPA
Feb 22, 2011 | Computers & Internet
Where shoild i find MAC based filtering in Netgear WGR614v2 router
The MAC address filtering is configured in the Wireless Settings - Wireless Card Access List then tick Turn on Access List - then click on Setup Access List and then add the device name and its MAC address. Eg My Laptop 00:19:4c:24:2b:71
Then click Add and continue adding each device and MAC address - when finished then click Apply and log out.
Nov 26, 2010 | NetGear WGR614 Wireless Router
How to obtain my password and add another laptop to wrt54G
To access the router's web-based setup page using Mac, click here. Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
Aug 23, 2010 | Linksys Wireless-G WRT54G Router
How can i put my linksys 54G a password
  1. Using the "Quick Installation Guide", follow the instructions in step 1 toset up your new wireless router. You may also need to restart your computer inorder to see the router.
    Note: If you normally use a static IP address, you will have toreconfigure your internet connection to use DHCP. Go into the controlpanel and open your network connections. Edit the properties of your currentnetwork connection, and make sure that "Obtain an IP address automatically" isenabled.
  2. Connect to the router using your web browser by typing"http://192.168.1.1" into the URL address box.
  3. Leave the Username field blank, and enter the password "admin" to accessyour router when the login prompt appears.
    Note: You will notice immediately a list of menu options (Setup, Wireless,Security, etc.), and as you click on each of these submenus appear. Thisdocument will refer to a menu-submenu combination as Menu -> Submenu.
  4. Setup -> Basic Setup. In the "Internet Setup" section, choose"Static IP" from the drop down menu. Fill in the appropriate values thatdescribe your network. (You don't need to change anything in the optionalsection just below that.)
  5. In the "Network Setup" section, you should at least set your timezone toEastern Time, although you may make changes to the DHCP server as well if youanticipate more than 50 users connecting to your network at once.
  6. Wireless -> Basic Wireless Settings. Set the Wireless networkmode to "Mixed" if you would like both B and G clients to be able to connect toyour network. Otherwise you can just select "B-only". The "Wireless NetworkName" will be provided by CNS. Make sure that you disable "WirelessSSID Broadcast" to give a little extra security.
  7. Wireless -> Wireless Security. CNS recommends that you use atleast WEP based security to protect your network. Choose WEP from the dropdown menu and then select "128 bits 26 hex digits" for the "WEP Encryption".Enter a passphrase into the "Passphrase" field and click "Generate" to generatethe corresponding HEX keys. Distribute key 1 to your users as the WEP key foryour network.
  8. Wireless -> Wireless MAC Filter. CNS also recommends that youuse a MAC address list to filter access to your network. Click the "Edit MACFilter List" and add all the MAC addresses that are going to be accessing yournetwork. Any time a new user requires access, you will have to add them tothis list.
    mac-filter.png IMPORTANT NOTE: Make sure that you add the MAC address of thecomputer you are using to set up your router first, before enabling this filter.Otherwise you will be unable to access the router and will have to reset therouter. If you do have to reset the router because you have locked yourselfout, there is a small reset button on the back of the router that will resetthe router.
    Once the appropriate MAC addresses have been added, "Enable" the filter, andchoose the option "Permit only PCs listed to access the wirelessnetwork".wireless-macfilter.png
  9. Administration -> Management. You should make sure you changeyour password on this screen. "admin" is not a secure password! Also,you should disable "Remote Router access" so that your router cannot beconfigured from outside your network. UPnP is a protocol that opens ports inyour firewall on the fly, and can post a security threat. We recommend thatyou disable this, but if you are running applications like MSN video chat, youmay have to have this enabled.
  10. Administration -> Log. If you would like to keep a log ofconnections to your network, enable the logging here.
  11. That's it! You should be on the air!
May 03, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Forgot how to put a new computer on my router that is locked
go to the router's setup page from the working PC. it usually accessible using browser. type http://IP address of the router (go to Start-Run-CMD-type ipconfig hit enter on the working pc and look for default gateway to check the IP address of the router- it is 192.168.2.1 by default).
It will prompt you to enter the username and password. type your router's password.
If you are trying to add a computer, check for MAC Filtering if it is enabled and make sure to add the MAC address of your new computer (Go to Start-Run-type CMD then hit enter- and type ipconfig/all and check for Physical Address). This physical address is the MAC address of the computer.
Nov 03, 2009 | Computers & Internet
Mac will not add printer
Hi, try to reset the print system as the apple article below:
SummaryWith Mac OS X 10.4, 10.5 or later, Printer Setup Utility includes a Reset Printing System feature, a troubleshooting function that you might want to use after you try all other printing troubleshooting stepsImportant: This feature should only be used as a "last resort" for troubleshooting a printing issue.
Products AffectedMac OS Printing/Fax (any version)
What does Reset Printing System do?
  • Deletes all printer queues and jobs.
  • Resets all printer settings to their default by deleting configuration files.
  • Performs a permissions check on the /tmp directory.
Any devices that previously appeared in your Printer List and Fax List will need to be added again after resetting the printing system.
Resetting the printing system in Mac OS X 10.5.x
  1. To use the Reset Printing System feature in Mac OS X 10.5.x, follow these steps:
  2. Choose System Preferences from the Apple menu.
  3. Choose Print & Fax from the View menu.
  4. Control-click on list of printers on the left side of the window, then choose "Reset printing system" from the contextual menu. If you don't see a list of printers, Control-click on the text "Click + to add a printer or fax" and select "Reset printing system..."
    As an alternative, if you currently have one or more printers listed, you can Option-click the "-" (Remove printer) button.
Resetting the printing system in Mac OS X 10.4.xTo use the Reset Printing System feature in Mac OS X 10.4.x, follow these steps:
  1. In the Finder, choose Utilities from the Go menu.
  2. Open Printer Setup Utility.
  3. From the Printer Setup Utility menu, choose Reset Printing System.
  4. Click Reset.
Additional InformationTip: If Printer Setup Utility won't open at all (possibly due to your printing issue), you can try to access the Reset Printing System feature directly by holding down the Option key while opening Printer Setup Utility.
Mar 14, 2009 | Apple Computers & Internet
I cannot access internet when connected to VPN.
1. Please assign an IP address to your computer using the IP Address Reservation.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. On the setup page, please click LAN IP Setup under Advanced tab.
e. Click Add under Address Reservation then you will be brought up to a new window.
f. On the Address Reservation window, please select the radio button of the computer you wish to add.
g. If the computer you want is not on the list; click the Refresh button to update the table.
h. If the computer is still not on the Address Reservation Table; please enter the IP Address, MAC Address, and Device Name of the computer you wish to add.
i. Please click on the Add button when finished.
2. On the Set Up page of the router, select on Port Forwarding/Port Triggering under Advanced tab.
3. Click Add Custom Service and type VPN on the Service Name box.
4. Set the Service Type to TCP/UDP and input the VPN port numbers under the Start and End Port field.
5. Type in the last digit of the IP address of your computer. Then, click the Apply button.
Example: The IP address of the computer trying to establish the VPN connection is 192.168.1.2.
Service Name Start Port End Port Server IP address
VPN1 47 47 192.168.1.2
VPN2 50 51 192.168.1.2
VPN3 500 500 192.168.1.2
VPN4 1723 1723 192.168.1.2
Dec 01, 2008 | NetGear WGR614 Router
Help! new users for Belkin wireless router
there are several reasons why this happens. dont use belkins utility use windows utility it will ask you if you right click the icon in the tray.
Jan 07, 2008 | Belkin (F5D5231-4) Router
Linksys Wireless-G WRT54GX Router (WRT54GX2) Logo
114 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
