Question about Bar Codes Pre-Mounted SC Tires w/Black Haz... - JCI3044-3264
Range Rover code 00127 What does it indicate
It is resorting to Trans Backup
    Problem Solver:
  • 11 Answers
I assume you meant (p0127) - means air intake temperature sensor malfunction.It always helps to list the year and model of the vehicle to get the most help possible.
Posted on Nov 29, 2013
Range Rover sport 2014 3.0d. Airbag light's on.odb code-b0028 right side airbag deployment control.any solutions guys? Thx
It should be a simple diag, as that fault indicates a short circuit between two specific wires, which just needs to be found. Dealer shall try to find it which wires in the areal of the trouble code.
"RF/Passenger Side Deployment Loop Resistance Low"
Apr 28, 2015 | 2014 Range Rover Sport
Range rover 2006 sport diesel auto trans not shifting in D mode only shift in triptonic I change trans control module but its showing u3000 code now what to do?
the transmission control module has to be programmed to the vehicle using suitable diagnostic equipment. the code you have got i suspect is telling you that, all the modules on modern vehicles communicate with each other via. the can and scp networks to work correctly. if that has not been done, that is more than likely the problem, or the road speed signal may be missing but i suspect you would have other fault codes logged. hope this helps. ps. i worked for a jaguar franchise before i retired, they use the same systems, same company.
Mar 17, 2015 | 2006 Land Rover Range Rover Sport
How to reset oil indicator light on a 2010 range rover LR4
get the OBD codes read and have them reset
Oct 14, 2014 | Cars & Trucks
My Range Rover 4.6 Vogue could not reverse at all. Kindly Advice
sounds like reverse clutches in transmission also check trans fluid
Sep 08, 2011 | 2000 Land Rover Range Rover
I have a 2004 Range Rover HSE . I had to boost the car many times after its been sitting for over 48 hours. I have replaced the battery by an OEM one but i still get the battery light flashing in the dash....
Sometimes that $125 an hour is worth it compared to the cost of replacing parts.....Define weak for the alt? They are either good or they are bad. If the voltage or current is low then there is a failure. What is your running voltage at idle? if it is 13v or lower than the battery is not getting a proper charge and will go dead from the draw of normal backup items. Also check all battery cables and grounds.
Feb 23, 2011 | 2004 Land Rover Range Rover
2003 range rover trans failsafe indicator. will not shift
have you transferbox Shift motor and your problem is solved
Apr 12, 2010 | 2004 Land Rover Range Rover
How easiest to refill Trans fliud?
funnel through transmission dipstick.
Jul 11, 2009 | 1999 Land Rover Range Rover
The rev counter indicates 500 revs on tick over
If you have the correct 4 digit code, you should be able to input it right in. After 3 unsuccessful attempts i will lock out. Push the BND button and hold until radio says code in.
2 ways to get the correct code
1. Giving your VIN# to the land rover dealer in exchange for the radio.
2. If that code doesn't work, you will need to have the radio pulled and provide them with the serial # to the radio and provide that to the dealer.
Mar 27, 2009 | 1998 Land Rover Range Rover
Bar Codes Pre-Mounted SC Tires w/Black Haz... - JCI3044-3264 Logo
76 people viewed this question
Top Jconcepts Vehicle Parts & Accessories Experts
Lawrence Oravetz
Mike
Stan Ford
Are you a Jconcepts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
