Question about D-Link DSL-2320B
What are the advantages of DSL and Cable modem?
    Problem Solver:
  • 6 Answers
DSL is PPPOE ( requires you to call up your DSL company and have them reset the PPPOE password every-time the modem gets reset) but with Cable this is not a problem trust me. I used to have DSL and I hated having to call up India everytime my dumb brother hit the reset button on the modem when his Internet was not working. Hope this helps and go with Cable!!
Posted on Sep 09, 2009
What is dsl modem?
Yes it can. The DSL modem is hooked to the phone line or cable and a network cable comes out of it. You hook that cable to the WAN port on the rout
Aug 19, 2014 | NetGear N600 Wireless Dual Band Gigabit...
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
    Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
    The DSL modem works on 2 different modes.
    You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
    To change the settings of the router, you will need to open the set up page of the router.
    Click Here for more information about the router set up.
    Feb 20, 2010 | Linksys WRT160N Wireless Router
    Not recognize my pc but not laptop
    I have yet to see a single DSL modem that will allow USB and Ethernet connections simultaneously (and actually work properly). You should install a DSL router instead.
    May 08, 2009 | AT&T High Speed DSL Modem
    Yes i want to find out if a cable modem will work with your dsl phone internet service?
    No.
    A cable-modem connects with a coax-cable to the cable-company's network, but a DSL-modem connects with telephone-cable to the telephone-company's network.
    Jan 27, 2009 | AT&T High Speed DSL Modem
    After successful instn of my linksys wireless router i cannot access to wireless online connection
    Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
    If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
    Cable users should have the router set to "Obtain IP aadress automatically"
    Use the reset button on the back of the router and start from scratch.
    Unplug the cable/DSL modem power
    Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
    Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
    Sep 25, 2008 | Linksys Wireless-G WRT54G Router
    CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
    The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
    Hope that helps..........
    Sep 06, 2008 | 2wire (1000-400108-001) Router
    Internet service to service routing
    you cant use a cable modem and a dsl modem at the same time as its a dsl dialler and a router and a cable modem works differently, all the settings wont match, you will have to purchase a seperate router or cable modem/router
    May 13, 2007 | 2wire (1000-400108-001) Router
    Open Questions:
    D-Link DSL-2320B Logo
    179 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
