Question about Panasonic NV-VX77 Camcorder
Salvaging old video camera tapes - Panasonic NV-VX77 Camcorder
Sony video handycam ccd fx420
The take up spool is no longer working. Time for a new V8 machine.
Jun 10, 2017 | Video Cameras
We have an Sony Video 8 AF. Camcorder is not working. Can and What can we use to transfer the movies we have taped to a more modern format?? Is there a cable or can you recommend a professional who can...
You can take your tapes to a video transfer service and get them to transfer to DVDs. Any large metro area will have these services but if not, you can mail off the tapes to a known service. Look online (google) for a reliable service with BBB rating and customer testimonials. Look locally first.
You may find a working Sony 8mm camcorder on your local Craigslist.com or at a Goodwill store or other second hand outlet or in the newspaper ads or online but that is unlikely since they are so dated. Remember that a Sony Hi8 camcorder can also read 8mm tapes so if you can find one of those for $50 to $80, they would read the tapes.
Lastly you could repair the camcorder but it may not be worth the cost. Local electronics repair shops may be able to fix the camera.
Apr 07, 2011 | Sony MSDW-904 Comopsite Video Input Board...
My tape was stuck in my camera. When I finally got it out and replayed it , it has lines running across the picture. When I did get it out part of the tape was hanging out so I rewinded it by hand. When...
The tape has obviously suffered damage and the cause is probably the internal mechanisms require service or replacement.
You can't repair the tape other than cutting out a damaged section and splicing together, not a good option.
I'd try running the footage through a Time Base Corrector to clean up the signal. In many cases this can restore unwatchable footage.
Al
Feb 11, 2011 | Sony Handycam CCD-TRV78E Camcorder
Sony ccd trv43 doesn't play hi8 after placing an old video 8 tape
Try to clean video head with cleaning cassette, if same position than video head need to be change
Mar 28, 2010 | Sony Handycam CCD-TRV43 Camcorder
Replay heads not playing back properly ,no sound ,like looking through venetian blinds ,used head cleaner but no better ,do i need new heads.
Have you used the same tapes over and over again? If so then reclean your heads and see if things work with a brand new tape. If this IS the case then I don't think what's on the original tapes will be salvagable.
Jan 23, 2010 | Canon MV700i Mini DV Digital Camcorder
NIGHT SHOT USED W/ TOO MUCH LIGHT MAY HAVE WRECKED IT.
"Nightshot" mode removes infrared filter from light path, fixes exposure to 1/60th second and sets iris to maximum.
Probably bad CCD, possibly could salvage from another camera.
Cameras are easy to take apart, but ribbon cables are VERY delicate and difficult to remove from connectors on main board.
My suggestion is to buy another camcorder, which uses the same tape and to use the old one to rewind tapes and for video transfers.
Dec 21, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Horizontal lines in my dv tape
TRY USING ANOTHER PLAYER IT MIGHT B YOUR CAM. TRY A HEAD CLEANER
Dec 16, 2007 | Canon ZR85 Mini DV Digital Camcorder
JVC Camcorder Model # GR-D270U
I thought this was a camera issue, but it ended up being a tape issue. So it shouldn't matter if you have the same model of the JVC mini camcorder as I did or not. Anyway, the tape has a tab that "locks" the tape to keep from recording over it accidently. I moved that tab and it started working. If your tape is stuck in the camera, you may have lost the tape already. Try to get it out of the camera without damaging the tape or the camera...more importantly the camera. You may have to take it to a professional to prevent damage. If you get it out undamaged, check to see if the tape is locked or not. Move the tab and try the tape in the camera again (unless you're afraid of it getting stuck again). In that case, try it in another camera. That's how I discovered that this was a tape issue rather than a camera issue...because I tried the same tape in a different camera and got the same error message. Don't despair if your tape comes out with part of it sticking out or crumpled, as long as it's not broken, you can salvage it. Even if it's broken, you can probably salvage the majority of the tape by taping it back together (call a professional, you may need special tape for this), just don't touch any of the undamaged tape or pull it out of the cassette too far and all you will lose is the damaged portion. I actually couldn't see the tab well enough to tell if it was in locked or unlocked mode since it's so tiny and my close-up vision is getting blurry, but I moved the tab to opposite of what it was and that seemed to do the trick. My mistake was in trying to save money with the cheaper tapes...next time I'll spend a little extra for the better tapes to avoid all this headache. Hope this helped. Have a great day!
Nov 30, 2007 | JVC GR-D33US Mini DV Digital Camcorder
Panasonic NV-VX77 Camcorder Logo
21 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
