Question about Excalibur RD50 Turntable
How to install new belt on turntable - Excalibur RD50 Turntable
  • 2,113 Answers
It's not hard Just do what you have to do. Take as many screws off that you need to do it
Posted on Nov 26, 2013
Thomas Pacconi TPC-MSE 800
could you include a picture of the under side of the turn table where the belt is fitted?
May 21, 2014 | Seth Thomas Pacconi Turntable
I have new belt and needle for kenwood 38r turntable how to install them
Belt is easy, Just remove the base, and change the belt.
Needle change is done by cartridge change. remove the old cartridge and insert the new one with the new needle.
Mar 18, 2011 | Kenwood Audio Players & Recorders
My sony pslx250h turnable belt was ordered and i can't find the repair book to repair it.
Pretty simple fix. Remove the mat, remove the turntable, install new belt on bottom of turntable hub. Place turntable back onto spindle. rotate turntable so you can see motor pulley. Stretch the belt from turntable hub over motor pulley, replace mat, enjoy.
Nov 08, 2010 | Sony PS-LX250H Turntable
HOW DO I INSTALL A TURNTABLE BELT FOR A SONY TURNTABLE
Under the felt of the turning section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 30, 2010 | Sony PS-LX250H Turntable
How do I change the belt on a rotel RP830 turntable. I can't see how to remove the turntable to install the new belt
There's a free downloadable manual at retrevo.com after you register.
It shows how to do it, sort of. I imagine the platter should just lift off which should expose the pulley and the driven part of the turntable. Make special note of which groove (top one) you route the new belt on for 33-1/3 rpm.
They don't mention it but you need to avoid touching the belt surface with your bare hands. Use cotton gloves.
Mar 23, 2010 | Audio Players & Recorders
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
LP Turntable
the platter must be able to spin freely without a belt installed as shown in this video
http://www.archive.org/details/Turntable_Belt_Installation
that would be one likely cause presuming you have the correct new belt that is.
Oct 26, 2008 | Panasonic Technics SL-DZ1200 Turntable
The belt on my turn table came lose
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things. if it keep coming off they can help you size a new one.
May 10, 2008 | Teac P-A688 Turntable
Too slow?
this can be caused be a new belt being too wide, you may need a narrower belt.
Dec 22, 2007 | Teac P-A688 Turntable
Turntable rotating slowly or not at all
First and foremost, are you sure you installed the correct replacement belt, and installed it correctly? Just ruling out the obvious. Now, if you installed the belt correctly, then the only other thing that could cause this is a bad motor. Not an expensive part, but with labor, it might be cheaper to just buy a new one. Figure the part itself is about You will more than likely be able to remove the cartridge/stylus and use it on your new turntable, just make sure the tonearm is the same style as your existing turntable - P-MOUNT Tonearm. If you buy another belt drive, you might even be able to keep the belt you purchased as a back up - might fit! Here is some part info on your turntable: - Belt - Part #SJY90080-3 - $5.99 - Motor - MOTOR, 4 VDC, .2 WATTS - Part #SDMB5E - $19.99 Labor - 30min This is just to give you an idea of what it would cost to replace the motor. I put the belt part # on there, just so you could verify that you bought the correct part. Hope this helps some. - Justin
Aug 02, 2007 | Technics SL-BD22 Turntable
85 people viewed this question
Top Excalibur Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Excalibur Audio Player and Recorder Expert? Answer questions, earn points and help others
