Question about Ariens Zoom XL 54 In 24 HP Kawasaki Zero Turn Riding Lawnmower ()
How does one adjust tension on drive belt on ariens 42 ionc riding mower
5 Suggested Answers
panilling9
  • 284 Answers
SOURCE: Cleaning
http://themojack.com/
Posted on Jun 29, 2010
SOURCE: need owners manual
http://www.ariens.com/corporate/pages/customerservice.aspx
Posted on Jul 18, 2010
  • 202 Answers
SOURCE: I need an owners manual for an Ariens Sierra 1640
Go you to this page and enter your model and serial number:
http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=0.8213132047263072&Site=ARIENSS
Good Luck
Posted on Dec 05, 2010
  • 18 Answers
SOURCE: need to know which fluid to put in transmission
reg car transmission fluid..works ..or put a bottle of lucas in it
Posted on Nov 21, 2012
My ariens mower will crank but when i let the clutchout it dies what is wrong with it
Take the belt (s) off and try. If it still shuts off then probably a clutch problem. If not make sure that drive system can turn and isn't locked up.
Jul 30, 2016 | Ariens 42 in 17.5 HP 6-speed Riding Lawn...
Zoom 42 mower deck belt routing diagram
Andy, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Zoom 42 mower deck belt routing diagram Google Search
http://apache.ariens.com/manuals/00173200.pdf
How to Replace the PTO belt on an Ariens Zoom Zero Turn
Ariens Zoom 42 Owners Manual
May 07, 2016 | Garden
How to change drive belt
  1. Step 1 - Loosen tension and remove belt. Locate the adjustment fastener and loosen it. ...
  2. Step 2 - Inspect drive and drive pulleys. Check the drive and pulley wheels. ...
  3. Step 3 - Select correct replacement belt. ...
  4. Step 4 - Install V-belt. ...
  5. Step 5 - Correctly tension new belt. ...
  6. Step 6 - Start the engine.
Mar 24, 2016 | Huskee Tractor Replacement Riding Lawn...
Why does the wheel Drive seems to slip / stop ?
no tension adjustments replace fluid and filter should improve
Jul 16, 2014 | Ariens Garden
Clutch chatter - Replacing the drive belt helped a little. Is there a way to adjust the clutch?
there is no clutch as far as I know on ride on mowers, there is just a tensioner pulley that works off the brake/clutch, to adjust it you have to depress the brake/clutch to take the tension off the belt then adjust the belt tensioner to apply more pressure on the belt. Also check the tensioner pulley as I have found that they split in two and the belt becomes loose as a result.
Hope this helps
Oct 20, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
I have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or jackssmallengines.com
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens 34 In. Zoom Series Riding Mower
Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Jun 21, 2009 | Ariens 34 In. Zoom Series Riding Mower
Disc drive slips under load & you have to jam shift arm to go rev
Check the tension on the belt tensioner....check to see if the belt guides are not under the belt anywher, rather over the top with 1/4 in clearance.....(the guides are just metal round bars either welded on or they are put on with a bolt (eye on the guides)
If the tensioner does not clear away from the belt, that would be why it shifts hard.
Apr 06, 2009 | Ariens Garden
Ariens Zoom XL 54 In 24 HP Kawasaki Zero Turn Riding Lawnmower () Logo
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
