Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
Taknless water heater leaking - Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
  • Rheem Master
  • 5,089 Answers
If combustion chamber is leaking, then probably cheaper to replace water heater.
Must have correct condensate drain, or acidic water will drip into combustion chamber and eat hole through metal, and then short out electronics.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
h
Posted on Nov 26, 2013
Repair a cold water leak at the bottom of my water heater
Hi -
If your water heater is working (ie: making hot water) then most likely your heater isn't leaking. Rather, the leak is coming from the cold water supply and running down the tank where you see it at the bottom of the tank. A working tank that is leaking would produce a leak of hot water - not cold. You should carefully check the cold water piping for a leak, drip or stream of water and make the required repairs.
Dec 02, 2014 | Water Water Heaters
My bradford white 50 gallon hot water heater Model # M250S6DDs NCWW Serial # E610822231 D/N
Depends on source of leak: If gas water heater is leaking from bottom, then heater must be replaced.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-water-heater.html
Add a comment and describe type of water heater, and what you discover about source of leak.
May 25, 2013 | Water Heaters
Leak inside water heater
1) Copy following link for troubleshoot walk-thru leaking water heater, and strategies for next water heater if needed.
2) If you have electric water heater, the element could be leaking.
Feb 22, 2013 | American Standard 40 G Natural Gas Water...
WATER HEATER LEAKING
1) Copy following link for troubleshoot walk thru
2) Electric water heater might be leaking from element, and water appears at bottom of tank:
Feb 12, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Is rumbling sound from leaking water heater dangerous?
Rumbling sound usually means sediment build-up inside tank.
Yeas a leaking water heater is dangerous because it can cause water damage.
Copy following link to determine source of leak.
Aug 28, 2012 | Water Heaters
What causes water heater leak and rumbling sound?
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Came down stairs water heater off and pan filled with water
Copy following link for troubleshooting leaking water heater.
You posted question under propane gas heater.
Propane is heavier and air, and this type gas water heater should not be installed in basement (below grade) since gas leak can fill basement with explosive gas.
Water leak does not cause gas leak, so water leak is separate problem.
Recommended for propane safety: install gas detector close to floor near gas water heater
Regular Natural Gas heater, install gas detector higher on wall since NG is lighter than air and will rise.
Aug 04, 2012 | Whirlpool 40-Gallon 6-Year Gas Water...
RHEEM 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF: water leaking from top of water heater how can i f...
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
May 17, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
