Question about Milwaukee Tool Milwaukee 6230 Deep Cut Portable Band Saw
PUTTING SWITCH IN MY HAS 5 WIRES NEW SWITCH USES ONLY 4
Bosch Rotak 32R. Why does it keep shutting down in 4-5 seconds??
Check gas cap for proper venting, will it run better with cap off.
Feb 13, 2016 | Garden
Suzuki aerio brake light switch
old post.
what year.
easy fix for any mech.
1: fuse blown.
2: brake switch bad,
3: wires bad.
4: PO (previous crazy owner) hacked in trailer wiring, and now
its all shorted out or he cut the wires, and uses useless wire nuts.
that are all corroded now , and useless.
5: collision damage never corrected.
first try it with one new light on each side , only 1, not 2
lamps can short easy (over twisting)
$1 for 2 new lamps, try that too.
Feb 01, 2013 | Suzuki Aerio Cars & Trucks
Ms 7613 ver 1.1
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01946060&printver=true
View the motherboard photo at the Top, and also the Motherboard layout illustration, at a little over halfway down the page.
1) In the motherboard photo, all the way to the right side. View the Yellowish/Whitish connector, that has two columns of 12 socket holes.
This is where the 24-pin ATX main power cable plugs in.
In the motherboard layout illustration it is labeled - ATX1.
Here is a general example of this power cable, and respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note that new Power Supply's, generally come with a 20+4-pin ATX main power cable.
This is so it can be used on the older computers that used a 20-pin ATX main power cable, and newer ones that need a 24-pin ATX main power cable.
Do not mix it's extra 4-pin power cable, with the 4-pin ATX +12 Volt power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
Note the Lock on the side/middle. It has a hook on the end. The hooked end goes over a Tab, on the motherboard's connector.
The Lock works on the same principle as a see-saw on a playground.
You squeeze the top near where the wires come in, and this brings the hooked end away from the Tab, on the motherboard connector.
With the top of the Lock still squeezed in, the power cable is then removed USING the connector. (NOT the wires)
When assured that the power cable is plugged in tightly, and correctly, the hooked end of the Lock will be over the Tab, on the motherboard connector.
2) Look to the left of the Processor socket, and halfway in-between it, and the outside edge of the motherboard.
Whitish 4-socket hole square connector.
This is where the 4-pin ATX +12 Volt power cable plugs in. Power for the Processor. Note that it also has a Lock, with a Tab on the motherboard connector.
In the motherboard layout illustration it is labeled - PWR1
General example of power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
That's it for the motherboard as for power cables that plug into it.
The rest of the power cables from the Power Supply, plug into the optical drive/s, harddrive, and card reader if used.
4) If your harddrive is an IDE (PATA) unit, it will use a 4-pin standard Peripheral power cable. Same with an optical drive that is an IDE (PATA) unit,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
The computer case fan plugs into SYS_FAN1 connector, which is below the PWR1 connector. You may also have a computer case fan that uses the above power cable.
5) If your Harddrive, or optical drive/s are SATA, they will use a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
6) A Card Reader uses a power cable, that is also used for a Floppy Drive.
It is a 4-pin Small Peripheral power cable.
Has the same voltage wires; (Yellow - 12 Volts, Red - 5 Volts), and two Black ground wires, but a smaller connector, than a 4-pin Standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
The front of your computer is the Front Panel.
The area of wires on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Although the Front Panel header has NOTHING to do with the Power Supply, I will include it also,
Motherboard positioned in computer case; Processor to the Top, Ram Memory slots to the Right;
The Front Panel header is at the bottom/right of the motherboard.
Black rectangle with 9 contact pins.
In the Motherboard layout illustration, JFP1 is marked under this header.
There are 4 pins across the Top row, 5 pins across the Bottom row.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the LEFT side going towards the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Reserved for factory use.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) Again, there is No Pin 10.
For additional questions post in a Comment.
Regards,
joecoolvette
Aug 15, 2012 | HP Computers & Internet
E-Machines T3508 PC Desktop Motherboard connecting the wires
The eMachines T3058 Desktop PC uses an Intel D101GGC motherboard.
The plastic front of your computer is the Front Panel.
The rectangular area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
Front Panel header:
This link takes you to Intel Support, and the download page for the motherboard manual, for the Intel D101GGC motherboard,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
On this page click on the blue -
Intel Desktop Board D101GGC Product Guide - English (PDF)
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
{ Took 7 seconds to download just now, with no additional download time needed.
Using medium speed DSL connection }
Ignore the following if you are aware;
At the top of the PDF file is the PDF file page number box, and the Zoom Out/Zoom In icons.
Zoom Out ( + ) enlarges the page view, Zoom In ( - ) reduces the page view.
For myself I reduce the view size to 100 or 75 percent.
The page number box is to the right of the Down Arrow.
(If you do not see this, hover your mouse cursor towards the bottom/middle. When the icons come up, {They were 'ghosted out'}, click on the PDF icon to the far right )
Provided that somehow you cannot download this motherboard manual;
Orient the motherboard so we are both looking at it in the same direction.
Same as it sits in the computer case.
Processor to the Top, Ram Memory to the Right, white PCI slots to the bottom.
The Front Panel header is at the Bottom/Right.
It is a rectangular block of plastic with two rows of pins.
4 across the Top, 5 across the Bottom.
It is numbered Even on the top, and Odd on the bottom.
Starting at the LEFT side going towards the right, on the top row;
There is no Pin 10, just an empty space.
Starting at the LEFT side going towards the right, on the bottom row;
A) Pins 1 and 3 are for the HarDDrive activity LED light. (Orange)
Pin 1 is for the Positive wire ( + )
If the LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. (Blue)
C) Pin 9 is for 5 Volts. Not Used (Black)
D) Pins 2 and 4 are for the Power On LED light. (Green)
Pin 2 is for the Positive wire ( + )
If the LED light is dim switch the wires around.
E) Pins 6 and 8 are for the Power On switch. (Red)
Do not know what wires coming from the Front Panel are the Power On switch wires, Power On LED light wires, or Harddrive activity LED light wires?
Remove the Front Panel, trace the wires to the Power On switch. (Two wires. Probably twisted together. Or all wires are in a single sheath)
Same for the Power On LED light, and the Harddrive LED light.
Need to know where the harddrive, or optical drive plugs in?
Need to know where the power cables from the Power Supply plug in?
Please post back in a Comment.
Regards,
joecoolvette
Oct 11, 2011 | E-Machines T2893 PC Desktop
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
I need trippers for parogon elect timer model # 4004-20
1) Paragon is no longer making timers or parts except defrost timers.
4004-20 240V 24-hour mechanical timer is not a defrost timer.
2) paragon 4000 series uses X2772 tripper.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
3) Some sites still show the X2772 tripper.
Some sellers are seriously overcharging for the tripper.
4) If you want to buy new timer: Intermatic cross-reference guide shows T-104 240V 24 hour is correct replacement timer
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
5) Amazon sells new T104 for 50$ which is cheaper than some folks are selling the paragon tripper:
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/tags-on-product/B000BQOX88
6) Change-over wiring from Paragon 4004-20 to T-104:
Hot wires from breakers. Paragon terminals 1 and 4. Intermatic terminals 1 and 3
Load wires. Paragon terminals 2 and 3. Intermatic terminals 2 and 4.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 08, 2011 | Hardware & Accessories
Need wiring connection diagram for Power Switch to Motherboard for EMachine W2925 model. Wires were disconected accidentally while cleaning inside of tower
micha219, the eMachines W2925 desktop computer uses an FIC motherboard.
First International Computer { Inc }
The Model Number of the FIC motherboard is VC37.
FIC VC37.
Disregard the following if you are aware:
The area on the Motherboard that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Processor to the Top, Ram Memory slots to the Right, the Front panel header is in the Bottom Right corner.
It is a rectangular shape with two columns of pins.
The length goes up, and down on the motherboard.
The pins on the Right side of the Front Panel header are numbered Odd.
The pins on the Left side of the Front Panel header are numbered Even.
There are 4 pins on the Left side.
There are 5 pins on the Right side.
Starting at the Bottom on the Right side going Up;
Starting at the Bottom on the Left side going Up;
A) Pins 2 and 4 are for the Power On LED light.
(If after connecting the LED light is dim, reverse the wires)
B) Pins 6 and 8 are for the Power On switch. (Power On button)
C) Pins 1 and 3 are for the HarDDrive Activity LED light.
D) Pins 5 and 7 are for the Reset switch. (Reset button. IF used)
Pin 9 is NC. Not connected
Oct 18, 2010 | E-Machines eMachines Desktop PC
Dell dimension 5510 it will not turn on, no
1/10th a volt? Nope.
Bypass the Power On switch. See if you have a bad switch first.
Then test the power supply. If the power supply comes on by bypassing the Power On switch, I'll bet you have a weak 12 volt voltage power rail.
1) Yellow wires are 12 Volts
2) Red wires are 5 Volts
3) Orange wires are 3.3 Volts
4) ANY Black wire is a Ground wire
They do sell power supply voltage testers, should you not wish to use a multimeter set at DC volts.
(0 - 50 Volt scale)
I prefer a multimeter.
A) ALL the light use less than 1 Watt
B) EACH fan uses 2 to 3 Watts
C) A typical Processor uses 55 to 125 WATTS.
You have to turn the power supply on, by jumping the Soft Power On wire to any ground wire.
This is also the way to bypass the Power On switch, to see if the switch is bad.
Do you wish to proceed?
Jan 15, 2010 | Dell Dimension E521 PC Desktop
Code reads # 6 cylinder misfire and primary coil ckt shorted
You auto has a 3.5L engine. Three of the cylinders are plain wires. #'s 1-3-5 are the front three.The rear cylinders are #'s 2-4-6. These three are "coil on boot". # 6 cylinder uses coil on boot. This wire appears to be defective. You can purchase a set of three coil on boot wires for around $40. Twist and pull to remove. Be careful when installing new wires; They break easily.
FixYaWIZ........saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Dec 09, 2009 | 2002 Kia Sedona
Plug wires
2 4 6 left 1 3 5 right
Nov 21, 2008 | 1994 Chevrolet S-10 Blazer
Milwaukee Tool Milwaukee 6230 Deep Cut Portable Band Saw Logo
29 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Craig Butler
Craig Butler
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
