Question about Frigidaire Dryers
Dryer runs but no heat. This just happened. - Frigidaire Dryers
    Sergeant:
  • 175 Answers
Hi..the reason to this problem is the heater element.
It might have got damaged.
check it out..
thank u..
kindly rate my response..
Posted on May 08, 2009
Why would a frigidaire flse60rgs1 combo dryer runs but not heat and washer not start?
check out house breaker and could be heating element problem or thermostat issues ,not enough info for more respond .
May 18, 2014 | Washing Machines
Why won't my dryer heat up?
There are several reasons for no heating on a Tumble Dryer. The heating element could be faulty ( open circuit.) There are several thermal cut outs which can also go open circuit The only way to check is with a Multi Meter by a qualified service engineer.
May 26, 2012 | Kenmore Dryers
Whirlpool dryer - ler4634pqo Runs fine but won't heat or shut off. Happened at same time.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 06, 2011 | Whirlpool Dryers
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
Amana model 2330aww....runs but does not heat up....just started happening, dried one load then it stopped heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 15, 2010 | Amana NDE2330AY Electric Dryer
My Roper dryer quit running...it's heating but doesn't seem to come on or tumble.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 20, 2010 | Dryers
No heat on any setting
if the dryer hasn't had a cleanout yes this can happen,but it might not be the element.you might have popped the high limit thermostat on the heater box,the dryer is running to hot from the air not moving correctly,a blocked vent line or the duct that the lint filter slides into is clogged with lint.unplug the dryer and with a meter check the thermostats and the heating element.pull at least one of the wires off the part you're going to check and clean out the dryer and vent line
May 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Is not heating
i think when this happened to my sister it was the heating coil. her dryer caught on fire. don't run it unattended.
Aug 01, 2009 | Kenmore 700 6972 Dryer
Dryer has no heat.
youve got an open circuit somewhere and its using another circuit to find ground
Jul 28, 2009 | Dryers
Dryer runs but doesnt heat
check the heating element and the limit switches there are the first things to look for when theres no heat
Jan 29, 2009 | Roper REX4634KQ Electric Dryer
Dryers Logo
44 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
