Question about HDMX Audio HMDX Jam Plus blue
Pairing instructions - HDMX Audio HMDX Jam Plus blue
Pairing to i Phone
Reboot iPhone. Go to Settings, Bluetooth, switch off and then back on. Power up headphones. Press the button on the headphones that you need to press to send the signal to the iPhone (this is the part that most people don't get). When found, click Pair on the iPhone. If it asks for a code the default is 4 zeros '0000'.
for instructions Google
make model manual
or
make model instructions
Jul 25, 2016 | Radio Communications
I want to pair my new cell phone with my headset 3xx plantronics but I need a passkey I don't have the instruction What can I do ?
Once you make your phone discoverable, then put the headset into pairing mode by pressing the call control button until it flashes red and blue. The passkey is " 0000 " (four zeros). Here is a link for the pairing instructions:
Plantronics Explorer Pairing Instructions
Good luck from Headsets Direct!
Oct 16, 2011 | Plantronics Explorer 220 Bluetooth Headset...
The headset works well but the communication with the base drops every 60 seconds.
Below are two links to help you with your problem. The first one is reset instructions from Plantronics. The second link is instructions for pairing the headset. If you follow the instructions, do the reset first then the re-pair.
Plantronics CS70N Resetting Instructions
Plantronics CS70N Pairing Instructions
Jul 28, 2011 | Plantronics CS70 Wireless Headset
Need pairing instructions
To pair your Plantronics Explorer 230, click on the following and should only take a few minutes with detailed instructions and picture:
How to Pair your Plantronics Explorer 230 Headset
Good Luck from Headsets Direct!
Apr 24, 2011 | Plantronics Explorer 230 Bluetooth Headset
Pairing instructions and code for pairing
paring what? please complete information thanks ^_^
Jun 03, 2010 | Anycom HCC-250 Bluetooth Headset
Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Jun 02, 2009 | Motorola Mobility HS850 Consumer Headset
I am trying to pair Visor Blade,Supertooth-Lite with mobile phone
Try holding down the green button release the mike then enter 0000 the phone should then pair. This worked for me so I hope it will work for you.
Mar 16, 2009 | Cell Phones
Explorer 320 pairing to motorola v323
i was giving a bluetooth with no instructions or codes how can i connect it with my unlimited boostmobile phone
Nov 01, 2007 | Plantronics Explorer 320 Wireless Headset
HDMX Audio HMDX Jam Plus blue Logo
238 people viewed this question
Top HDMX Audio Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a HDMX Audio Medical Expert? Answer questions, earn points and help others
