Question about Singer Sewing Machines
Skipping stitches i think my singer stylist 543 needs adjusted; i would like to do this myself; need how to help
5 Suggested Answers
  • 980 Answers
SOURCE: I have a Singer Stylist 543. The feed is not
If you have taken the needle plate off recently make sure you have put it one correctly, failing that you need to get underneath the teeth by taking the machine bottom off and you will see a large screw that you can adjust
Posted on Mar 09, 2010
  • 1116 Answers
SOURCE: Need an owner manuals for singer stylist 533 sewing amchine
None I found are free, but this one downloads for $8.
http://www.sewconsult.com/singer/singer_instruction_manuals.htm#500
Posted on Apr 16, 2010
Testimonial: "Excellent resource"
SOURCE: TENSION ADJUSTMENT ON SINGER 9836C
try adjusting the top thread tension to one number higher at a time until the stitches start looking right
also check with singer customer service for a instruction manual
Posted on Feb 24, 2012
SOURCE: how do I set up my singer stylist 533 for flexi stitch?
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number(example 533)
Click search
Posted on May 17, 2012
How do i adjusting the foot pressure on singer confidence stylist 7467S
I glanced through the owner's manual and did not find anything about presser foot pressure. Unfortunately, some machines do not have this capability. If you need more pressure, you might try adding paper or tear-away to add body to the fabric you are stitching.
Singer 7467 Confidence Manual Table Of Contents
Feb 24, 2018 | Singer Sewing Machines
How to change needle position (left, right, center)
Which stitch are you using? As far as I can tell, the Stylist 7258 only allows you to change the needle position for straight stitches. If the machine is set to Pattern 00, press the right or left buttons from the 4 arrow keys in the manual setting arrows until the needle is in the desired position.
For all other stitches, the left/right arrows adjust the stitch width. This is described on page 30 (in English) of the manual. You can download the manual from the product page under the support tab: http://www.singerco.com/products/2101/7258-stylist#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/4951b452e963a8fe1dd1fd83fbac68a35df8cf19.pdf .
I hope this helps.
May 23, 2016 | Singer Stylist 7258 Electric Sewing...
Where do I take my sewing machine to get fixed?
sadly we have no idea where you live , so we can not check for you. try the singer website at singerco com
May 13, 2016 | Singer Sewing Co 7258.CL Stylist Sewing...
My Singer Stylist 9100 has constant problems with the top thread being too tight. It is causing me a lot of stress trying to sew the simplest of things. Please HELP!
My Singer Stylist 9100 has constant problems Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Instruction Manuals
Basic Maintenance Tension Skipped Stitches
Singer 9100 Instruction Manual Thread Tension
Six Common Sewing Machine Problems Solved
Mar 23, 2016 | Singer Sewing Machines
Skipping stitches
Skipped stitches
1. A bent or dull needle
2. The wrong needle for your fabric
knit fabrics require a jersey or ballpoint tip. Most wovens do well with a universal tip, and specialty fibers, like leather or metallic, usually require specific needles.
3. Incorrect machine threading
4. Unbalanced needle thread tension
Start by making relatively small changes and run a test stitch to evaluate the impact. If you need to adjust the tension dial using woven cotton fabric with good quality all-purpose thread and a new needle
5.check the needle is inserted correctly. The needle needs to be pushed as far up the needle shaft as possible. It's easy to insert the needle half way, clamp it down and think it is inserted correctly.
the flat part of the needle should be positioned towards the back. If the needle is not inserted correctly, it will not be able to pull up the bobbin thread and will cause skipped stitches.
6. If the suggestions don't help then it is time for a tune-up.
Nov 19, 2013 | Singer 7256 Fashion Mate Sewing Machine
Singer Stylist 11 Serger problems with right need skipping stitches how can I solve the problem
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
Jan 04, 2013 | Sewing Machines
Mar 09, 2010 | Sewing Machines
Sewing Machines Logo
24 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
