Question about Case Logic Radio Communications
How do you operate bluetooth CL-BT001-BK
There is no instruction manual in the Bluetooth box. would like instructions in order to pair with my cell phone. would like to pair Bluetooth wit my I Phone.
Scanned manual available but is too large to load here. Basically, all functions are handled by the phone, the headset's only control is the on and off switch.
Posted on Feb 13, 2014
  • 3 Answers
SOURCE: bluetooth
Press the all-in-one button for about 8 seconds until the light is constantly on, this puts it in pairing mode. then go to your device and initiate pairing. the device code is 0000.
When done the blue light should shut down, and your all set.
Posted on Nov 10, 2007
shanth
  • 108 Answers
SOURCE: Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Posted on Dec 22, 2007
SOURCE: samsung bluetooth device pass key ?
Try 0000
Posted on Jul 27, 2008
SOURCE: Pairing Plantronics-E220 Bluetooth w/ my Pantech Matrix C740 Cell
Hold down the call button on the headset and wait for it to flash slowly blue. Make sure your phone is in "discoverable" mode. You should see your phone asking to connect to the plantronics headset. When it asks for a code, enter 0000.
Posted on Jan 03, 2009
SOURCE: Lost N136 Manual
I have an N136 which turns out to be an HS850 (with folding boom}. This model requires the boom to be folded while the answer button is held down, When the light comes on the boom must be extended before the light goes out. The light will now stay on and the phone should find your headset.
Posted on Feb 12, 2009
How do i set the language on a bluetooth cl bt001 bk to english
Basically, all functions are handled by the phone. The only control on the headset is an on/off button. Have a scanned image of manual but it's too big to load here.
Jan 21, 2014 | Case Logic Radio Communications
I can not pair my phillipson bluetooth #BCK08A to my blackberry curve. How do u pair them together?
Make sure you are in "pairing mode" by holding down the Multi Function Button (MFB) until the red and blue flashing alternately. When the device is off, holding down the MFB for about 5 secs will turn the device on; however, don't release the button and continue to hold until red and blue flashes. Then, you are in pairing mode.
May 06, 2011 | Philips Cell Phones
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
My blackberry 8520 wont pair with Ford audio
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
1. On the BlackBerry device, in the device options, click Bluetooth.
2. Click the trackwheel and click Add Device. The Select Device list appears and lists devices that are in range and available to be paired.
Note: Only devices that are in range and are in pairing mode will appear in the available device list.
3. Click the device to which you are pairing. The Enter passkey dialog appears.
4. Enter the passkey to authenticate the device. Most Bluetooth devices contain a hardcoded passkey. See your Bluetooth device manual for the passkey.
Best regards
Apr 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
Can't pair Samsung C3053 with Motorola bluetooth. I have followed the directions to use the Bluetooth messenger (whatever that is) and have gone to (in order) Menu, Settings, Messages, Bluetooth...
any one of the cell might have newer ver of bluetooth whicdh other 1 cannot recongonise.... try some other bluetooth headsets of own brand
Apr 10, 2010 | Cell Phones
How pair bluetooth Jabra vbt2050 with a blackberry storm 2
Mar 04, 2010 | RIM BlackBerry Storm2 9550 Smartphone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Forgot pairing passcode for BK 600 bluetooth headset
the passcode should be 0000 I've looked into two manuals for it I think I may have to look in to a 3rd? let me know if that didn't work and I'll triple check it.
Thanks,
Ekse
Feb 20, 2009 | Cell Phones
I need a instruction maual for a itrax bluetooth device
Pairing With A Bluetooth Enabled Cell Phone
1. The BTCK06 and the Bluetooth enabled cell phone should be within a distance of 3 feet
(1 metre).
2. With the BTCK06 OFF, press the MULTI-FUNCTION Button (The bottom button) for 6 seconds.
The Red & Blue LED's will flash alternatley and the speaker will make a long BEEP sound.
3. The Bluetooth cell phone will search for nearby Bluetooth devices. The cell phone will display the
BTCK06 in the list of Bluetooth devices. If you are using a "dongle" type Bluetooth adaptor,
follow the manufacturer's instructions for that device.
4. Select BTCK06 to add this Bluetooth device into the list of the paired devices.
5. Enter in the PIN Code "0000" and your mobile phone will show that pairing is complete.
6. If Pairing is successful, user will hear a long BEEP and the Blue LED will flash about every
3 seconds.
Nov 24, 2008 | Cell Phones
Radio Communications Logo
657 people viewed this question
Top Case Logic Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Case Logic Radio Communication Expert? Answer questions, earn points and help others
