Question about Logitech Harmony 890 LCD Remote Control
Remote battery level extremely low, charger not charging it
The battery has been changed but the remote still doesn't charge
ripleymojica
  • 643 Answers
SOURCE: I even bought a new battery and the remote still will not charge.
not the battery. open the base and raise the three little brass charging contacts. i used a file to shave the plastic on remote contacts to get it to seat better on the base. if you mash on the remote while on base and it starts to charge then do the mod.
Posted on Jul 02, 2009
  • 4 Answers
SOURCE: My 880 will not charge I used this 2 years ago and
There is a trick with these remotes. Take a tiny piece of paper and
wedge it in between the battery and the side of the battery compartment
opposite the battery contacts when you insert battery.
This will apply more pressure between battery contacts and remote.
Now your harmony should properly charge up overnight.
Had the same problem with mine and the paper trick fixed it.
Was even able to use the old battery again.
Has something to do with the three contacts on the battery.
All 3 need to make good contact.
Posted on Nov 19, 2009
Testimonial: "didn't work with new replacement bat all that happened was the test process and press -> symbol and then I get a red circled ? in the top right"
SOURCE: Harmony 785 charging cradle does not charge the remote
Try pressing down on the remote, and wiggling it around. It's just that the pins are not making contact I suspect.
If pressing down helps, you can fasten it on with a elasitc band or something so that it keeps charging. Also, if it is still under warranty, I woul advise contacting Logitech's wonderful support team to get replaced.
Hope that helps!
Posted on Mar 05, 2010
Testimonial: "Thanks - this solution helps."
SOURCE: Remote not charging on screen, has a picture of a
If your Harmony remote is not charging on the base, try pressing down on the remote, and wiggling it around. It's just that the pins are not making contact.
Also, I would suggest a firmware update.
Hope that helps!
Posted on Mar 06, 2010
SOURCE: HARMONY 890 REMOTE WILL NOT CHARGE. I HAVE NEW
Hi, This is actually a fairly common issue. There is a design flaw with the 880 and 890 chargers that causes the pins to no longer make contact after a while. Good news is that to buy a replacement charger is only about $10.
You can try pressing down on the remote, and wiggling it around. It's just that the pins are not making contact. If pressing down helps, you can fasten it on with a elasitc band or something so that it keeps charging.
Posted on Apr 07, 2010
How long should the battery charger to get a full charge
It depends on the level of discharge of the battery and the rate of amperage charge generated by the charger. If possible check the fluid level (acid/water) in the battery. If it is too low the battery will not accept a charge. If you add water (distilled) to the battery you charge at a low amperage charge rate if possible. A fully discharged battery may take 12 - 24 hours to reach full charge.
Oct 11, 2016 | Health & Beauty
Phone shows its name while plugged in and repeat the same process over and over but does not charge
Sounds like the battery has corroded or gone bad. TRy Zbattery.com for extremely low price.
Jan 17, 2015 | Cell Phones
8520 blank changed display still blank
see this steps and fix it. God bless you
Restart iPhone
Sometimes all it takes is a restart for the iPhone to become responsive again. To restart your iPhone when it is unresponsive, press and hold the sleep/wake and home buttons until the Apple logo appears (~10 seconds).
Very low battery
It is possible for an iPhone to become unresponsive if the battery drops to an extremely low level. Plug the iPhone into your computer or wall charger and allow it to charge for at least 20 minutes before using it again.
Jun 20, 2013 | Cell Phones
TracFone is charged, but says it is not charged and will not turn on.
Hello':":":":"
PHONE CHARGING:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
2:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 20, 2013 | LG Cell Phones
Hand vacuum doesn't charge
If the plug in charger works, the batteries are boiled out and need replacement.
They should not be left on charger all the time. Just charge them for 10 hours and use them until the performance has dropped off, then and only then put it back on charge for 10 hours.
Sep 28, 2012 | Dirt Devil Extreme Power Wet Dry Hand...
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
Second Option:
Jul 26, 2012 | Huawei Impulse 4G
Battery wont hold a charge overnight but starts right away with a jump or battery charger and runs throughout the day
sounds like the electrolyte levels in your battery are extremely low which will cause it to not hold a charge except over the day when the alternator is constantly recharging it, ask a mechanic to either top it up or buy a new battery
Jun 25, 2009 | 1998 Plymouth Breeze
Battery Charging
If both the charger and the battery are warm to the touch, the battery is probably charged.
The low battery level warning level is learned by the phone. To train it, allow the battery to run down once until the phone stops working, then recharge it.
The best way totest the charging operation would be to try using the phone. Fully charged you should get about 6 hours of talk time from a fully charged battery, and at least a week of standby operation.
Dec 25, 2007 | Motorola Mobility V176 Cellular Phone
Logitech Harmony 890 LCD Remote Control Logo
15 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
Andrew Taylor
Andrew Taylor
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
