Question about GE (PSS26MSRSS) Side by Side Refrigerator
Unit not running and back freezer panel very hot
GE profile side by side refrigerator stopped running.  The back panel of the freezer unit was very, very hot to touch.
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    How old is this unit?
    Problem Solver:
  • 14 Answers
Sounds like the sensor for the auto-defrost is not working.
Easily replaced.
You will need to find a local appliance parts shop, take the model number along.
Explain the problem. By gettign the part first you can figure out what you are looking for inside.
Usually it is a simple unplug and plug in operation.
You will have to open the unit. Only takes a screwdriver.
Posted on May 08, 2009
Ge tfg27pfxa profile with cooling problem
Remove the back panel in the freezer to see if the defrost heater is running continually.
Nov 06, 2012 | GE Refrigerators
I have a 15 year old side by side ge profile refigerator. The floor of the freezer constanly freezes order and leak under the freezer side, What is the cause?
LOOK IN SIDE THE FRZ ON BUTTEM BACK WAY LOW BACK THER A DRAIND AND IS PLUG UP OR FROZER NEED TO UN PLUG TRY TO USE HOT WAER AR A HOT STEMER TO UNPLUG DRAIN.
Feb 21, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice build-up in bottom of freezer due to stopped up drain. I Know how to get drain unstopped, but don't know easiet way to melt ice in bottom of freezer. Have tried hair dryer, but I am afraid I am going...
Very common, remove the back panel in the freezer pour hot water down the drain hole. The defrost drain line is blocked, I know this unit very well can help you more if you need, let me know,
http://www.appliancerepairlesson.com/
Mar 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice/Water dispenser not working on my GE Profile Arctica model # PSS26SGPA SS. Does make ice though, just front panel stopped working. Called a tech to troubleshoot, who said it was the main...
Had same problem. Removed kick panel at bottom and found the wires from the freezer door near the lower hinge are very flimsy. The white wire was broken at the connector and the connector was corroded. Since I have no plans to remove the freezer door, I spliced the wires together with **** connectors and it's working fine.
GE could do better.
Jan 12, 2011 | GE Profile PSW26P Stainless Steel Side by...
The freezer is slowly rising in temperature(0-18 deg in a week, still set at zero) and either side of the unit by the freezer door are very, very hot. Unit is about two years old. Fridge temp is slightly...
Check the condenser fan motor in the back, bottom of unit. pull off lower panel. Fan should be running when unit is running. Also check the condensor coils underneath or in back to make sure they are clear.
Jun 02, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
GE Profile Artica side by side - freezer not cold enough
replace control board on back of unit there is a six by 10 inch cover on back your panel is in there cost aprox 169.00 dollers also replace bo0th thermisters bottem left of freezer looks like a white bullet the other is in fridge behind shelf trim located beside and underneath where the cold air blows into the fridge.
Aug 10, 2009 | GE Profile PSI23NCR Side by Side...
GE Refrigerator/Freezer not cooling
Loss of coldness is common with compressor related problems....relay and overload(simple fix), loss/leak of refridgerant(need a cert. tech). need to check the compressor and see if its running....do this by pulling the unit out and removing the back panel, place your hand on the compressor and see if it feels like its running....if not probably just a relay, if it is running, could be a more serious problem dealing with sealed system.
Jun 10, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Blocked defroster drain GE profile tfx25pr, tft25pr
Remove the freezer bins and shelves.
Remove the rear freezer panel.
The drain is on the bottom center of the freezer after the rear panel is removed.
May 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water on Floor Outside Freezer (Side by Side)
take a wire and run it through the drain until there is no resistance and then put hot water into it.
Mar 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
My GE Profile is 1.5 yrs old and I have the same problem. I came home to find all my food spoiled! It seems many GEs have had this problem, I agree GE should do something, there are expensive units.
Jun 17, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
135 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
