Question about Little Giant APCP-1700 Swimming Pool Cover Pump Automatic
Pump will not run
Pump not working
  • 2,760 Answers
I get calls on this from time to time , heres what ive found to be cause in a few in past
breaker that feeds outlet that pump is plugged into has tripped
the auto sensor points on pump motor cover are covered up with slime and leaves
pump impeller is clogged with leaves and tree fallings
Posted on Mar 05, 2015
I have a 1998 Jeep Cherokee I was driving it and quit running the fuel pump quit running and the gas gage stopped working
check your fuel pump relay. if not that, then it's your fuel pump. the gas gauge is in the fuel pump, so if your fuel pump stopped working, your gas gauge won't work
Mar 12, 2016 | Jeep Cars & Trucks
Spa is warm only. It seems that the heater pump only works when other pump runs
as this is a 220 volt system you need to be sure both sides of the elect line is proving proper voltages at each junction.
one might fail some where at a switch or breaker an let some functions still kinda work. like in your case.
Nov 28, 2014 | Pool & Spa
Hi!how to check fuel pump work or no. rav4 54reg.
If the engine runs the pump works. Try this. On the starter motor there is a small diameter wire that can easily be removed. Pull this wire off the starter and hold the key in the start position. The starter will not operate. Listen for the fuel pump to see if it's running while you hold the key in the start position. If you can hear the pump running then it's ok. This trick works if you ever run out of gas too. It will run the pump until gas pressure is back so you don't have to run the battery down trying to start an out of gas engine.
Oct 09, 2013 | 2002 Toyota RAV4
1998 chevy astro van sometimes works, sometimes not.? At timesm rarely, the astro will crank but will not start. Fuel pump not cycling and making its hum noise so I changed the fuel pump with an AC Delco...
When you first turn on the key, no crank, the fuel pump should run for a few seconds then stop. There shows to be an oil pressure switch in parallel with the fuel pump relay. It's just a redundant power supply to the fuel pump. Once it cranks enough to bring up oil pressure and the switch closes, the pump will run even w/o the relay. Both the fuel pump relay and oil pressure switch get voltage from the ecm b fuse.
At the fuel pump connector, check voltage and ground, when problem is ongoing. Gray wire is voltage--black wire is ground.
You could pull the fuel pump relay, use jumper wire between terminals on load side of relay. The load side is that line with arrow head, when energized that line moves to the other terminal. As you can see, the orange wire is hot all the time, the gray wire carries voltage to fuel pump. If it runs with jumper, then check control side of relay, the control side has to have voltage and ground, dark green wire with white tracer is voltage comes from pcm. The black wire is ground.
Mar 13, 2017 | Chevrolet Astro Cars & Trucks
Pump over heats and stops running
any time a pump over heats and stops running is
A. the pump is bad.
B. the float is stuck and the pump is causing it self to run and run until it over heats and shuts down.
C. Something is clogged in the pump and restricting the flow and causing the pump to work harder and over heat and shut down.
D. the check valve is bad, stuck closed, something stuck in check vavle.
May 18, 2010 | Flotec Plumbing
I have a Fimco 2.1 gpm pump that worked fine last week. I ran it until it didn't spray anymore. This week the motor runs but it seems to have lost its prime,it won't pump.Any ideas? The filter is clean. No...
I don't think that these pumps run dry very well ... most likely you ruptured a diaphragm by running it dry. How long did it run dry? ... take it apart and see if the diaphragm or valves are damaged. You will need to replace them before the pump will work.
Jun 25, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fuel filter or fule Pump?
i,d say start with filter first. if it was the pump it wil not run pump work or dont work
Apr 08, 2009 | 2003 Mitsubishi Outlander
Washer fluid not working
Remove the pump from the tank and make sure there is no junk stopping up the pump.
allso if the pump does run and there seems to be no stoppage,then replace pump.
running dry some times damagers the impellar that pumps fliud.
Please rate this solution
Dec 17, 2008 | 1998 Chevrolet Astro
Little Giant APCP-1700 Swimming Pool Cover Pump Automatic Logo
249 people viewed this question
Top Little Giant Garden Experts
J.D. Browning
J.D. Browning
Jim Goldsmith
Jim Goldsmith
Mike Squire
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
