Question about RCA OPAL M4001 MP3 Player
Driver fails to install
It comes up and thing but after a few seconds its says fail to install...when i check device manger it tells me something about cannot start
  • Anonymous Mar 04, 2009
    Im having a similar problem accept even when its connect it wont charge either. Seem like a hardware issue. Also if I tell the hardware manager to update my driver its names it as an mtp device.
    Problem Solver:
Try to use real player
Posted on Oct 13, 2007
SOURCE:
I need help please anyone i have no sound coming from my hp stream 11-d009tu i have uninstalled and re installed my auido drivers and still nothing
step by step inch by inch
BT sound ok
HDMI sound ok
main sounds dead. at internal and at ext. 3.5mm line out jack dead.
that means BIOS has that chip off , so go to BIOS and turn it on
if it is on, the get the driver from HP
you have yet told the full service tag data here.
so i cant even go to hp for you and ask them can I.
so why dont you go to hp and ask them
and they will ask you for the service tag, or fails.
Jan 02, 2018 | HP Computers & Internet
I have the cam plugged into my computer and the green light wont turn on so my cam doesnt work
Hi! i would like to help you with this.
First clue helped me understand that the green light wont turn on, which clearly says that there is no power supply for the webcam.
second thing i would like you to try is.
*please check for loose connectivity issue.
*please check of the port in the computer( where you plug in the cable) or the connector pin is damaged, broken or loose.
*then please check of the driver is installed in the DEVICE MANAGER.
How to get into DEVICE MANGER:
*please click START> RUN.. type in "devmgmt.msc" and click OK.
*then the device manger will open. there you can see drivers for keyboards and all hardware components. please look out for "imaging devices". if you expand it.... you will find the webcam driver.
** if there is any exclamation, question or X mark on it. please let me know. there might be some problem in the driver installation.
** also please let me know the operating system and please check if you installed the webcam software.
please let me know if you need more help. Thank you:)
Oct 23, 2010 | Logitech Quickcam Chat Webcam
Tried to load HP Laserjet 3015 s0ftware with printer plugged in. That failed. Now getting "finds new hardware" when I try to load the software even though nothing is plugged in. software is not asking me...
The thing is printer is automatically detected by the system and there was no proper driver was installed and it is in device manger installed as other device with yellow mark. Just uninstall it. And click on scan for hardware changes. To go to device manager right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | HP LaserJet 3015 All-In-One Printer
Printer will not print
Make sure you install the driver properly and check the test print also .still if u fail check all this setting and follow this steps, 1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd
Sep 24, 2009 | HP Officejet 5610 All-In-One InkJet...
False driver message?
make sure that the driver is not installed go to start, right click on my computer, click the hardware tab, and click device manger. If you see any yellow shields that means drivers need to be installed. I would got to the laptops website and get the drivers
Jun 05, 2009 | Computers & Internet
Lite on cd/rw/dvd rom (SOHC-5236V) fails to read dvd's
your dvd lense might be dusty OR laser might have became weak
try upgrading FIRMWARE
Jan 31, 2009 | Lite On SOHC-5236V CD-RW/DVD-ROM Combo...
I have the sound divice but i cant play any thing and i dont here
possible sound device failed, or drivers not the right ones, my newer note book had failed sound device (code 10 cannot start) it started doing static when listening. the failed all the way. i now use an external sound device myself that was about 15 dollars now i have sound again without large cost. this may be an option for you.
Nov 18, 2008 | Digidesign Mbox External Sound System
My new hp w2207h monitor, pop up keep telling me to install driver. when i install driver a error message comes up.what should i do.
Go to - CONTROL PANEL - DEVICE MANAGER then find monitors in the list,right click the desired device, then PROPERTIES this will tell you if the device is working properly. then click update drivers. If this fails check your screen resolution settings. The safest thing is to set it to default.Sometimes the graphics card isnt big enough for the monitor so try tweaking visual settings like shadows and fonts. Things like message box outlines and shadows can be turned off too speed the image up.If your using vista your probably using the default theme AERO/GLASS. Change it to a normal theme of your choice but dont use GLASS. this uses quite alot of graphics power.
Oct 25, 2008 | HP Computers & Internet
DVD Drive not recognised!?!
control panel > system and maintenance > system
device manager
devolp + IDE ATA/ATAPI Controllers
reinstall device ICHx
Jun 03, 2017 | Artec DHM-G48 (ar16x) Internal DVD Drive
Acer Aspire 5050-3242 - Orbicam Not working
Hi if you are using WinXP install SP2 so that your Cam is recognized and then install the corresponding driver for the Cam .
May 24, 2008 | Acer Aspire 5050-3242 Notebook
RCA OPAL M4001 MP3 Player Logo
44 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
