Question about GE Profile JTP18 Electric Single Oven
After self clean ge oven states unloc door - GE Profile JTP18 Electric Single Oven
  • 100 Answers
SOURCE: Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Posted on Oct 31, 2007
SOURCE: GE P7 Oven
I, too, have lost my manual and none of the timers work. I can never remember how long to run the clean cycle for, but will turn it off as it has been a little over 2hours and your post mentions 1.5hours.
I initiate the cleaning cycle by completing steps mentioned above and then turning the top dial (which has a clean range on it) clockwise until the clean light comes on. I then just time it by my watch to turn it all off. Then I wait a couple of hours before attempting to open the door. Don't forget to take the racks out, they are not suppose to go through the Clean cycle.
Good Luck,
Linda
Posted on Dec 20, 2007
vest6
  • 196 Answers
SOURCE: "Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
Posted on Jan 26, 2008
SOURCE: Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Posted on Mar 18, 2010
  • 189 Answers
SOURCE: GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct".  This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash.  The grease is now a hard rubbery coating on the surface of the rack.  To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good.  Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth.  Turn on to 450deg for 30 min.  Much safer, less costly.                                                       Please acknowledge this posted solution if helpful.  Have more info if needed-  Thanks  -Ed
Posted on Mar 24, 2010
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
Why is oven door locked and won't open?
Self-cleaning GE ovens have a locking oven door as a safety feature. ... How to Troubleshoot a GE Artica Profile Refrigerator That Won't Get Cold ... Allow the oven to cool down if there is food inside the oven, and unlock the door once the ...
Oven won't open!!! [Archive] - Chronicle Forums
www.chronofhorse.com > ... > Off Topic
The Chronicle of the Horse
Dec 25, 2010 - 100+ posts - ‎100+ authors
Different ovens unlock at different times, some are by temp and some are ..... -cooktops/19645-ge-oven-door-wont-unlock-after-self-clean.html)
Dec 30, 2015 | GE Ovens
F9 error code appears within two hours of self clean cycle
F9 error code on GE ovens is usually caused by a problem in the door lock/latch system for the self clean. You state it happens about 2 hrs into the clean cycle. My guess is the the control is not sensing that the door is actually locked. Could be several reasons. Bad door lock motor, Bad switch that senses the door is latched, or is some cases the main control board could have a problem and is just not reading the door is locked. You need someone with the right knowledge to trouble shoot which part is actually bad since it could several different problems.
Mar 10, 2015 | GE JTP75 Electric Double Oven
GE 1978 Slef Cleaning oven JKP26002wh 3 Layers of glass in door...How do I clean between the glass in the self cleaning aluminum window mechanism?
You will have to take the door apart to get to the glass that needs to be cleaned out. I would not recommend doing a self clean on an oven that is that old.
Dec 07, 2010 | GE JTP75CMCC Oven
I'm getting a F2 Error and door locked with flashing and beeping after I ran the self-cleaning mode on my GE Model JTP85 built-in oven.
f 2 code states that your oven temp exceeds 590 w/unlocked door .. the oven tempt sensor will need to be replaced .. hope this helped mm
Dec 04, 2009 | GE JTP85 Electric Double Oven
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
LOC for oven door is unable to unloc
Put the oven in Self Clean mode for 3 minutes and then cancel.. if if that will release the relay that controls the lock. If that doesn't work, Unplug the oven for 10 mintues, then plug it back in holding the CLEAR button down. If neither of those work you will need to contact a service repair man.
Jul 19, 2008 | Ovens
GE Profile JTP18 Electric Single Oven Logo
23 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
