Question about Viper Vehicle Parts & Accessories
We have a viper 4105v remote start for my wife's car. We recently had a dead battery and now the doors will not lock or unlock and the remote start turns the engine over but it does not start. I assume there is a reprogramming sequence that needs to be done but I do not have a manual.
  • 22 Answers
SOURCE: the battery was taken out
Put the key in the ignition turn in two clicks. Take the key out hold down the program/valet button on the remote start then hit the unlock button on the remote.
Posted on Dec 04, 2008
SOURCE: the battery in my VW key fob is dead, now I cant start the engine
No. VW has made it nearly impossible to solve any key-related problems without a costly visit to the dealership. Battery must be replaced, and I assure you. the dealership will advise you that the ONLY place that you can find that particular battery is from the dealership. They like it that way.
Posted on Jan 20, 2009
  • 899 Answers
SOURCE: got a new remote for my viper 791XZ and reprogrammed it .
this usually means that the remote did not recieve a signal back from the module or the module did not recieve the remote signal
have you tried repeatively to press the unlock button? does the remote starter work or aux( trunk ) ?
also when putting the battery in the remote , be easy because there is a connector plug soldered on the board real close to where the battery is , and if it is hit by the battery hard enough it will cause those solder connections to disconnect and you will get the beeps and or other malfunctions
Posted on Feb 03, 2009
  • 899 Answers
SOURCE: viper remote stopped working 791xv
I have the same remote and it comes disconnected in the battery section from the battery hitting it and then the commands and speaker stop working
as shown here
Posted on Apr 05, 2009
alzhane
SOURCE: Need to reprogram door locks for 2004 Toyota Camry
I recently replaced the battery on my 2004 Toyota Camry. When I installed new battery the door locks will not stay unlocked once opened with remote. How do I reprogram?
Posted on Apr 07, 2009
MY VIPER 4105V REMOTE START STOP STARTING THE CAR. I NOTICE THAT IT TRY TO START TWICE BUT JUST WON'T TURN OVER. EVERYTHING WORK EXCEPT THE REMOTE START. STOPPED WORKING AFTER 4 MONTHS.
I would highly recommend you have the Viper removed from your car permanently by an experienced professional or you will most likely have other problems later as a result of this item being fitted (if you ever get it working again which I doubt).
Nov 30, 2015 | Viper Vehicle Parts & Accessories
My viper alarm 7153v, I try to unlock the doors and it wont unlock, i try to lock the doors and it wont lock, i try to remote start my truck and it wont start what should i do?
First, check the battery in the remote control unit. It may be dead, or the battery contact has broken loose from the board and needs to be resoldered. If the remote control unit looks good, check the receiver in the vehicle. Make sure the wiring harness is properly connected and undamaged and the fuse is good.
Aug 04, 2015 | Viper Vehicle Parts & Accessories
Door locks unlocks
may be the remote was opened ad the pads inter changed
Mar 21, 2014 | Viper Vehicle Parts & Accessories
I have a Viper 5301. Just recently the blue light on the valet stopped blinking when the car is locked with the remote. It just stays on all of the time, no blink. At the same time, the remote started...
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Apr 14, 2011 | 5301 LE 2 Way Car Remote Starter System
Will not unlock doors. Battery is good and flashes all lights on transmitter and LED inside vehicle. Remote start will start up and shut down vehicle fine. Just does not lock or unlock doors. Locks work...
Have you changed the battery recently? My remote has a bad habot of slightly misaligning the cel switches if I don't close it exactly right. For my Chrysler van the sliding door switch is affected that way. All else works, though. I end up opening the remote again and ensuring it snaps shut all the way around with just one compression. If an edge doesn't close it's try again. The good news is it's virtually always the remote at issue and nothing expensive in the vehicle.
Jun 06, 2017 | 7900 RB 7900 2Way Color LCD Remote Start...
Remote car starter worked last week but this week it won't start. Changed battery in the remote and still won't start. It will unlock and lock the doors but just won't start.
It probably needs to be re-programed
I have a viper model 5101 and this is how you program it Hope it helps !
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Jan 05, 2011 | Remote Start System
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
Viper works but remote start and keyless entry does not
On the remote start part, it might be as simple as relearning the tach. To do this, crank the car with the key, press and hold the valet switch until the led lights and stays solid now release.Try the remote start. Need to know what kind of car to comment on doorlocks.
Jun 14, 2009 | Viper Security and Remote Start System...
Vehicle Parts & Accessories Logo
1,093 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
