Question about Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook
Macbook line-in is phase-inverted
The built-in line-in on my new macbook makes every recording phase-inverted.
I've tried the same external audio source on another computer and it was normal.
  • 25 Answers
Have you checked the software preferences of your sound editing software? Seems to me there are some options to reverse the phase with in certain software applications.
Posted on Aug 22, 2009
Backup macbook pro harddrive
you can use the OSX built in "Time Machine" and connect an external HD or even better a Time Capsule WiFi station from Apple.
Can use Apple Time Machine to restore to new MacBook Ask Dave Taylor backup-macbook-pro-harddrive-abadwnk1mj4brvvpzp1wcyyy-4-0.jpg AirPort Time Capsule 2TB
Oct 17, 2013 | Apple MacBook Pro Notebook
Hi my MacBook pro screen isn't working. Any solutions?
Have you connect your macbook to an external monitor? If this works then it might not be too bad (lcd inverter) but if no signal comes to the external monitor then it might be bad. Try this 1st before doing anything else.
Apr 28, 2011 | Apple Computers & Internet
I use Microsoft Word for Mac 2008 on my Macbook Air to take notes on and record the audio of my lectures (in notebook view). The internal microphone is not particularly powerful, so I have an external...
Microsoft Office needs to be compatible with the external microphone. Just because your MacBook recognizes the mic through the adapter doesn't mean OneNote does.
Apr 01, 2011 | Microsoft Word 2008 for Mac
I have a Macbook Air with Microsoft Word Home and Student 2008 installed on it. I use the audio recording feature on in Word to take notes in lectures, but since the internal mic was not enough to capture...
In sound system preferences when the external mic is plugged in, there is a drop down menu in the input tab that says "Use the audio port for:" make sure it says input.
Mar 22, 2011 | Apple MacBook Air
Okay I have a 2008 MacBook and my boyfriend bought me the Bose Companion #2 Speakers and the speakers sound out of phase when I up the volume. It sounds horrible from a different room you can even hear it...
Hi.
I would get an external sound card running on either USB (minimum 2.2) or firewire. I have had problems with mac audio ports. M-audio make a good range and so do ION. You need a stereo 2 in 2 out minimum (no need to overspend unless you plaun on starting a home recording or video project).
I would check to make sure there is no kind of phase switch on the speakers in anyway first though.
Jan 14, 2011 | Bose Companion 2 Series II Multimedia...
Got a MacBook Pro...problem recording with external microphone
Hi
... sound issues like you are having do pop up occasionally ... the best thing to do is to reboot the system ... sorry.
Cheers.
Apr 29, 2017 | Apple GarageBand Jam Full Version for Mac...
Digital Audio out in MACBOOK PRO.
Connect external speakers, headphones, or optical digital audio equipment. The headphone / line output jack accommodates optical digital audio output, analog audio output with a 24-bit, 44.1-192 kHz D/A converter, digital audio output up to 24-bit stereo and 44.1-192 kHz sampling rate and supporting encoded digital audio output (AC3 and DTS). For analog headphone / line output a standard audio cable with 3.5mm metal plug should be used. For digital audio, a standard Toslink cable with a Toslink mini-plug adapter can be used.
You can find the Digital to Analog converted:
http://tinyurl.com/9ms8mv
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Apple MacBook Pro Notebook
I have an io26 firewire audio interface linked to my macbook. When i record in cubase le4n i'm only getting sound out of the left headphone and its seriously quiet. I have set the audio/midi settings to...
your audio are not in interface with your macbook it means to say, the common wire are not in the same connection. that why you only hear sound on your left headphone. in short your firewire audio is not compatible with your macbook. but you can rewire it with same audio plug. or replace the audio plug with the compatible one. when you do this, make sure that the common wire of your firewire audio and your macbook are in the same connection.
Nov 07, 2008 | Computers & Internet
M-audio firewire 410 on macbook
Use a 'Y' splitter. Usually from balanced to unbalanced. Also try looking at your device's control panel and see if you can change the channel options from mono to stereo. Beta drivers are for testing purposes, so try the signed driver also.
Mar 08, 2008 | M-Audio FireWire 410 External Sound System
No screen activity on startup
hi wa_flyboy,
I suggest you first do a test to determine if it is your macbook's screen or graphics processor which is at fault. To do this you need to connect an external display to your macbook.
The macbook has a mini-DVI port for connection to external displays. Depending on the connector of the external display you use to do the test, you are either going to need a mini-DVI to DVI adapter (for a DVI display) or a mini-DVI to VGA adapter (for a VGA display). These adapters are sold separately by Apple, see http://store.apple.com/1-800-MY-APPLE/WebObjects/AppleStore.woa/wa/RSLID?nnmm=browse&mco=669DFFE0&node=home/shop_mac/mac_accessories/displays
If an image is displayed on the external display after you have connected it to your macbook, you know that the screen of your macbook is faulty. In this case it would be an economical option to take the macbook to a repair shop where a technician can determine the faulty component (either one of the following display components of a TFT LCD screen can fail over time; the inverter, the backlight or the cabling). These can be replaced under warranty or they can order new ones if the warranty has expired.
If the external display shows the same symptoms as your macbook's display, it is the macbook's graphics processor which is at fault. I'm sorry to inform you that I think this is the cause of your macbook's display problem. Replacing the graphics processor of your macbook entails replacing the motherboard.
If the macbook is still under warranty I suggest you replace it and let technicians migrate your data from your current macbook's hard disk to your new one.
If the warranty of your macbook has expired, it's a more economical option to buy a new one and migrate your data to the new macbook. This will only cost a few dollars more than the cost of replacing the faulty motherboard (including the service costs of the repair shop to which you take your macbook), but is still more economical seeing as how you get a new machine which has a full warranty.
I hope this is helpful information and thanks for using the FixYa services
Kind Regards
Feb 13, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook Logo
139 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
