Question about Samsung Hue (SCH-r500) Cellular Phone
Can't unlock Samsung Hue?
My daughter's phone is locked and none of the default codes work and the code she used doesn't work. She was in phone settings and changed it also from nam 1 to nam 2. The phone restarted and now says intiial programming needed and wants an unlock code. Can you Help?
  • jaschr May 21, 2009
    Alltel
  • m3xicanad3co Sep 23, 2009
    help???? i cant unlock my samsung hue. how can i unlock it???
Samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
hahah
Posted on Aug 11, 2009
    Problem Solver:
  • 10 Answers
Solution number 1 worked for me the only thing is when you go to edit you have to reenter your number for it to work =)
Posted on Sep 02, 2009
  • 41 Answers
What service provider
Posted on May 19, 2009
  • Ty;er Caird May 22, 2009
    mhhhhhhhm is this pay as you go?
SOURCE:
Hi, a found my old phone in draw but forgot unlock phone code, can anyone help please? emei 354847/01/258856/8
The default phone lock code for Nokia mobiles are 00000 or 1234 . You can try with them. If it doesn't work, You can get the master reset code from www.Wickedunlock.com at affordable cost. master resetting would change your phone to default factory settings.
May 05, 2012 | Nokia 6110 Cellular Phone
I changed the default lock code 12345 and typed a personalised code,but then i forgot it and now my phone is locked.hwow do i reset or deactivate this security code,the phone is a Nokia 6210 Navigator.
http://unlock.nokiafree.org/6210 try using this website. if it doesnt work, you may have to take it to a cell phone unlocking store. doesn't take more than about 10-15 minutes to unlock and restore factory lock code
Aug 15, 2011 | Cell Phones
Hi, i want to lock my c6 phone with a passcode or password!! becoz of my brothers provoking my privacy??
To activate lock code on Nokia C6:
  1. Select Menu
  2. Settings and Phone
  3. Phone mgmt.
  4. Security settings
  5. Phone and SIM card
  6. Select Lock code
You can also set the phone autolock period to avoid unauthorised use, set a time-out after which the device automatically locks. A locked device cannot be used until the correct lock code is entered. To deactivate this option, select None.
Jun 29, 2011 | Nokia C6 Smartphone
Nokia 6300 imei no 356960011934838 master restor code
Changing the security code
Of course, if any potential phone thieves are reading this, they'll now know the default security code is 12345.
To change the security code, go to Menu > Settings > Security > Access codes > Change security code. When prompted, enter your current security code and click OK. The enter your new security code (a PIN between 5 and 10 digits in length), click OK and enter the new code again to verify it. Click OK and you'll see the message 'Security code changed
or
*#7328748263373738# resets security code.
Default security code is 12345
Jun 27, 2011 | Nokia 6300 Cellular Phone
My phone 6120classic is formated in the type of *,3,call button but my security code is doesn't change how can solve this?
I just had the same problem. Performed the green key, * and 3 button. Still came up with the enter lock code screen. Just enter the default 12345 and should be fine, then go into phone settings and turn off the lock code on change of sim card. Hope that helps. Keep in mind it will wipe your phone clean back to default. The lesson here is don't forget what you change your code to, I have learned my lesson.
Jun 04, 2011 | Nokia 6120 classic Cellular Phone
Security Code for Nokia 1100
Hi there!
By default, the security code for your phone is 12345. If that doesn't work, then you probably changed it to a different code before. You'll have to bring the phone to a qualified technician if the phone is locked with the security code to unlock it.
Hope this helps.
May 14, 2011 | Nokia 1100
My daughter locked her cell phone up by accident
the default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up also please vote for me I'm trying to work my way up to expert level and I cant without your vote please
Jun 05, 2010 | Samsung Smooth SCH-u350 Cell Phone
I had pressed Phone lock accidentaly and now it is
Default code is 000000. Also, if you set the voice code, you can always press the voice buttom and speak out the code.
Apr 20, 2009 | Motorola Mobility A1200
W385 Motorola
try the last 4 digits of your mobile telephone number
Jul 26, 2008 | Cell Phones
Locked samsung G800
thanks excellent
Jun 15, 2008 | Samsung SGH-U600
Samsung Hue (SCH-r500) Cellular Phone Logo
1,276 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
