Question about Samsung HM322IX 320GB 7200RPM 2.5" SATA Laptop Drive
Samsung HM322IX SATA - Samsung HM322IX 320GB 7200RPM 2.5" SATA Laptop Drive
I have replaced the hard drive on my HP G5000 laptop with a Samsung HM161GI drive. All tests OK on BIOS diagnostics, but Windows XP Setup says no hard disk is installed??
This happens because the hard disk is natively a SATA and XP doesn't have a generic SATA driver so from its point of view the disk is not there. You will need to go into the BIOS and set the SATA connection to use the legacy/IDE mode.
May 16, 2011 | Samsung Spinpoint M7E HM161GI 160GB 5400...
Master/slave settings on sp411c samsung drive please SATA
The SATA hard drive did not have master/slave setting at the hard drive
if you want to make the hard drive as master just connect your hard drive to SATA 1 slot at Motherboard
and id you want to make the hard drive as slave just connect your hard drive to SATA 2 slot at *********** board
i hope this helpful
thank you for using fixya
Feb 09, 2011 | Samsung Computers & Internet
My samsung sata hard disk HM120JI is not working fine. Windows is not coming up. I have replaced the hard disk and now want to copy data from samsung sata disk to the new disk. Could you please tell me how...
You can buy a SATA dongle that plugs in to the hard drive and plugs into the USB port on you computer $20 or buy a external SATA case to put the hard drive in $40 at most computer retailers.
Feb 06, 2011 | Samsung SpinPoint M60 HM120JI 120 GB SATA...
Sata driver for Samsung harddisk
You need driver SATA controller that is used on your motherboard. You need to find CD or download from internet, drivers for your SATA controller that is used by your motherboard. Put this *.inf files on bootable Floppy diskette. In Windows XP setup press F6, when it askes you. If you found correct driver you will see your HDD in setup.
Apr 16, 2010 | Computers & Internet
I have a samsung 2.5" sata hdd that I want to make it from a master to slave. I need a pin jumper setting info.
You dont need jumper settings for sata hard drive, the sata ports on *********** board have the configuration, just connect the new hdd to the 2nd sata port.
Mar 24, 2010 | Samsung (MP0804H) 80 GB Hard Drive
I have a samsung hmo 6011 harddrive can i replace it with a samsung f3 sata 11 drive
If the samsung hmo 6011 harddrive (couldn't find that model) is SATA then yes, and SATA drive will work. The only thing to make sure is that you get the right size; for a laptop or PC. If the samsung hmo 6011 harddrive is IDE (has pins) then no, they cannot directly replace with a SATA.
Here is a good comparison picture http://www.laptopparts101.com/wp-content/uploads/2008/12/sata-ide-laptop-hard-drive.jpg
Feb 03, 2010 | Computers & Internet
Samsung SH-s203 dvd writer is compatable with this motherboard
put the sata cable to sata terminal and also connet the sata power cable to drive.
Oct 28, 2008 | Intel D845GVSR Motherboard
Samsung 250GB HD250HJ SATA II.
Most likely if it makes sound then it is getting ready to crash, don't take a chance and remove your files and replace.
Jun 29, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
ASUS VIA KT133
Your motherboard does NOT support SATA drives, without an added SATA controller. It does support PATA drives, such as the Samsung SP2514N and the Seagate PATA drive you listed, as well as any other PATA drive. A PATA drive may be referred to as PATA, IDE, ATA100, ATA133, or even ATA66, but not SCSI, Ultra320, U320, or SATA, SATA II, SATA100, SATA300, etc.
The Seagate drives are easy to identify, their model number ends in AS if it is a SATA drive, and just A if it is a PATA drive.
Dec 05, 2007 | ASUS VIA KT133 Chipset A7V133 Motherboard
Samsung HM322IX 320GB 7200RPM 2.5" SATA Laptop Drive Logo
116 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
