Question about Toshiba Satellite A105 Notebook
Can't open the top of the laptop. Is there a lock ? OR how do I open it?
  • Chris Hingee
    Chris Hingee May 11, 2010
    Are you trying to open the lid of the laptop to see the LCD screen?
  • 909 Answers
I assume you mean the display panel.
On the front there is a slide switch, in the middle.
Just slide to the right and lift the lid.
Posted on May 09, 2009
HP keyboard is locked
  1. Power your laptop off completely.
  2. Take the battery out of the laptop. Typically the battery is located underneath the laptop towards the top.
  3. Leave the battery out for 30 seconds. This will allow the laptop to refresh itself.
  4. Put the battery back into the laptop.
  5. Power your computer on. Once your computer has rebooted, check to see if the keyboard is working.
  6. Open the "Start" menu on your laptop, if the keyboard is still locked up.
  7. Click on the Control Panel.
  8. Go into the "Accessibility" options.
  9. Open the tab labelled "Keyboard".
  10. Make sure none of the boxes have a check in them. If the laptop has Microsoft Vista as the operating system, go to the "Ease of Access" option and go to "Change how your keyboard works." Make sure none of the boxes in that section are checked.
  11. Click the "Save" button.
  12. Exit the Control Panel and begin typing to see if the keyboard is now working.
Jun 25, 2014 | HEWLETT-PACKARD Elitebook 8460P
How disassambel laptop medion md41700?
Model not found on support site MEDION UK Manual But laptops have small screws holding them together. And snap locks that need to be released gently. I use my finger nails or a razor blade to start pry open the release snaps. To open up a laptop after removing the screws. Each laptop is different, keyboards usually can be removed after removing any screws and prying up from the top (where the F keys are" other screws are under there for getting to the motherboard.
Cables for keyboard video differ by models and makes as well. You have to know the type of connector used for removal and re-locking when putting back togther.
May 20, 2014 | Computers & Internet
Replace batteries for light voyager
FLIP IT UPSIDE DOWN AND NEAR THE TOP AND TO THE RIGHT AND LEFT SIDES YOU WILL SEE SLIDE BUTTONS. ONE IS FOR THE BATTERY LOCK AND ONE IS TO LOCK THE NOTEBOOK SHUT. JUST SLIDE THE BUTTON AND YOU WILL BE ABLE TO OPEN IT.
Jan 19, 2013 | Acer Computer AOA150 Notebook
Hp dv6000 keyboard not working properly
When you use your HP laptop for work or just to surf the Internet, it's very frustrating when the keyboard locks up.
It can also be expensive if you need to hire a professional to fix your keyboard.
Luckily, whether you know what caused the keyboard to lock up or not, often with advanced troubleshooting you can solve this problem yourself.
Open the tab labeled "Keyboard".
Hope this helps
Nov 08, 2012 | HP Pavilion dv6000z Notebook
Scroll lock on mousepad get locked
Try: To toggle your scroll lock key:
  1. Click on the Windows Start button.
  2. Select Run.
  3. Type 'OSK' in the dialog box.
  4. Click on OK.
  5. The Microsoft on-screen keyboard will open. Notice that the slk, or scroll lock, key (located in the top row of the on-screen keyboard as shown below) is turned on.
  6. Click on slk (in the top row of the on-screen keyboard). This will toggle the state of the scroll lock key. Notice that the scroll lock key is no longer outlined in red. Scroll lock is now off.
Aug 29, 2012 | Lenovo INC 102495U Z570 Ip Ci321 156...
Eee pc900hd keyboard lock
Hook a external keyboard to the laptop, if okay! unless you have pressed something that locked it down, the laptop keyboard will need to be changed. But if both have same problem you may have a virus, device driver issue. If mouse pad works try a system restore before this occured.
Mar 19, 2012 | HP Mini 110-1037NR Netbook
I had to reboot my lap top and now my wifi on it wont work
just click the restart.by clicking start menu/shut down/restart.
to on your WiFi.press the fn key and the WiFi key located on the f keys at the top of the keyboard.some laptop have a lock on the side to open the WiFi.just check your laptop on both side.you don't need to press fn/WiFi key it is having the WiFi lock on the side.
Sep 23, 2011 | Toshiba Computers & Internet
Laptop Lid will not open
There are two metal hinges that are on that laptop model and are at top of laptop near keyboard and screen joint. When one of these hinges breaks, and they do, it can become jammed. By continuing to try and open it you run the risk of damaging the LCD on the laptop. The top of the laptop has to be removed to access the hinges and replace them. This is not something a novice can do easily and is dangerous to the laptop. If its not under warranty and you feel comfortable with your skills you can try. However I would recommend a repair shop. The hinges for this model run about 10 dollars for the pair and the labor would be whatever the local rate is. To see the hinges that are for your unit.. this link has a good picture http://battery-adapter.com/product_info.php/products_id/3463
Sep 27, 2009 | Computers & Internet
How to remove key board from bakard bell easy note sw51-201
Mary,
At the bottom beside the lock sign take out the screw. Open laptop and move the top part panel to the right this will open the keyboard acces..
Jan 14, 2009 | Computers & Internet
Battery replacement
At the top or above of the battery there are 1 or 2 lock keys First unlock them then remove the battery If u Provide laptop model then it will b good to answer................
Shubham........................
Jul 26, 2008 | Samsung V20 XVC 2400 Notebook
Toshiba Satellite A105 Notebook Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
