Question about Woods WD25G Dehumidifier
Replacement filter Which filter do I use for this dehumidifier
Where in north bay on. can I purchase a replacement filter for my kenmore 36 dehumidifier?
Hello, Mike -
You MAY be able to find the right filter to order for your Kenmore dehumidifier on the website PartSelect Canada:
https://www.partselect.ca/
or on the website Easy Appliance Parts Canada:
https://www.easyapplianceparts.ca/
or on the ShopBot Canada website:
https://www.shopbot.ca/m?q=Kenmore+dehumidifier+filter
Best wishes.
Jun 01, 2018 | Kenmore Dehumidifiers
How do you clean the air filter?
The cleaning of Dehumidifier Air Filter is very simple, Air Filters are washable. Just remove the backside part of the device and take out the air filter. Wash it with water and fix it.
https://www.vackerglobal.com/divisions/dehumidifier-humidifier/desiccant-dehumidifier/
Feb 20, 2016 | LG Dehumidifiers
How do I change the filter on my dehumidifier lad704tdl
The filter on the Frigidaire LAD704TDL is behind the louvered section of the housing above the water bucket. Remove the water bucket by pressing the sides gently to release the bucket from the dehumidifier. Then pull the bucket towards you and use the handle to move it away. Then reach up and pull the filter down. You can wash the filter or replace it with a new one.
For pictures, see the manual: manuals.frigidaire.com/prodinfo_pdf/Edison/66166042enaen.pdf . The filter maintenance is shown on page 8.
I hope this helps.
Mar 09, 2015 | Dehumidifiers
What should I do when the air filter light comes on?
Good Afternoon Friend, that's a great question!
Typically the FILTER RESET light will illuminate after 250 hours of operation. To locate the filter, remove the bucket and the pull filter downwards. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions. Hope this helps! - Z
Sep 11, 2014 | Frigidaire FDL50R1 Dehumidifier
I just replaced the two filters in my Sante Fe Compact dehumidifier, and the coil and filters froze up in a week. The temperature is above 70 degrees. What could be the cause?
Air restriction in the connected ductwork.
Dirty coils reducing air flow thru dehumidifier.
Low refrigerant charge.
Phone the factory at 1-800-533-7533 for help troubleshooting.
Sep 10, 2014 | Santa Fe Compact Dehumidifier
Removing the filter model fdl7051
Hello Friend, this is Z. Thank you for allowing me to assist you!
You would need to remove the bucket to locate the filter of your Frigidaire dehumidifier (FDL70S1). Then pull the filter downwards for cleaning. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions and typically the FILTER REST light will illuminate after 250 hours of operation. Hope this helps!
Aug 12, 2014 | Frigidaire Dehumidifiers
How to clean the filter
Good Afternoon Tad, thank you for allowing me to assist you!
First remove the bucket to reach the filter of your Frigidaire dehumidifier, FAD504DUD. When you locate the filter, pull it downwards. The filter can be clean by either washing it with clean water or using a vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once the filter is reinstalled then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier will resume normal operations.
Hope this helps!
Jan 31, 2014 | Frigidaire Dehumidifier Fad504dud
Do I have a filter I need to change in my dehumidifier MHDW
i assume you have a humidifier and not a DEhumidifier? putting water in a dehumidifier defeats the purpose. it should remove the water from the air. don't fill the tank on the bottom. empty it. as for the filter, just use a vacuum across the front fins to remove the dust.
May 10, 2012 | Windchaser MDH-W Dehumidifier
Runs but no water appears in container, also the filter light does not come on when button is engeaged, why is no water collecting? is there a filter I should be replacing? Thanks, Matt
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Frigidaire FDF70S Dehumidifier
My dehumidifier continually runs and removes little water. I cleaned the front filter and the manual says to clean the back filter but I can't get to the back filter. How can I reach it to clean it?
heatman101
May 31, 2011 | Haier 45-Pint Dehumidifier
Woods WD25G Dehumidifier Logo
63 people viewed this question
Top Woods Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Woods Dehumidifier Expert? Answer questions, earn points and help others
