Won't spin but everything else works fine.
Have a Roper top loader bought in 1994 - model number RAL5144BWO. Its been fine all these years. Starting yesterday it will not spin. All other aspects work fine. It agitates, it rinses, it drains. The only thing it won't do is spin. It does not make any unusual noises. It actually sounds normal and like it is spinning but when you oepn it up on the spin cycle you can tell it is not spinning. Any idea as to what the issue is?
  • sportguy67 May 08, 2009
    Actuually found out it was what they call the driver, brake cam. Plastic pice that is part of the brake and drive tube. Dad and I took it apart today and discovered this broken piece, went ot the parts store and replaced it. Appears to be fine now. Thanks!
    Sergeant:
  • 175 Answers
Hi..sounds like a rubber belt got too hot and broke.
Replace it with a new one.
check it out..
thank u..
kindly rate my response..
Posted on May 08, 2009
Roper washer rax7245awo won't spin/aggitate
is this a top loader??there are clips on the edges of the top..they require use of a regular screw driver(flat blade) inserted between the top and sides..them it should pry up and tilt to the back..on hinges..
Feb 02, 2014 | Roper Washing Machines
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
My machine is not spinning what may be the problem
depends on what brand and type of unit... is this a front loader a top loader and what brand.. is it direct drive or belt driven.... if it is belt driven could be a bad belt or pulley...if it is direct drive such as a top load whirlpool ,kenmore,roper, you could have a bad drive coupling which is located between the motor and transmission under unit.... if this is a front loader there are numerous items it could be example a motor controller board, main pcb board.
if everything is working but the spin mode and this is a top loader unit may want to check the lid swich that will cause the unit to not spin.... hope this helps kinda a vague description of your probelm....good luck and give me a vote i need them....
Jan 03, 2011 | Washing Machines
Leaks when the washergoes into the spin cycle.
Could be crack on underhose or possible drum fault
Sep 30, 2009 | Roper RAS6233KQ Top Load Washer
Everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
May 31, 2009 | Roper RAX4232KQ Top Load Washer
this is a whirpool style direct drive. most likely coupler is broken. it's a small part, between motor and gearcase about as big around as a silver dollar but thicker. lean the washer back so you can look under it and look right behind the motor. not a major repair. worth fixing. You will want to remove the cabinet so if you decide to do it mssg back for more info.
May 24, 2009 | Roper RAX4232KQ Top Load Washer
Have a roper ras7133kq1 top loader. It will fill with water and will do nothing else. when i manually set it to spin it makes a squealing nose and the water just drains out.
go to www.repairclinic.com and enter your model number. the first part you see is what is wrong with your washer's spin. replace that and you'll be good. this is found underneath between the motor and the transmission.
Apr 03, 2009 | Roper RAS8445KQ Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
Have GE GJSR2130 or
is this machine top loader or front loader
Mar 15, 2008 | Washing Machines
Mo del RAB 1121EW1 serial number CG 402 1770
This is a direct drive washer so there is no belt. The drive coupler that connects the motor to the tub may need to be replaced.
Mar 05, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
