Question about Mitsubishi WD-62825 62" Rear Projection HDTV
Jump picture after 15 minutes picture gets purple static lines and picture starts jumping
  • 3 Answers
Sounds like there may be some coronal arcing in the second anode circuit connection to the CRT's. (20,000 vdc High Voltage!) This usually occurs when contamination and moisture build up a resistance path around the cap at the connection point, or any point where the leads may be contacting the metal chassis would do that also. WARNING: If you have no experience with this, DO NOT attempt to solve it yourself. This voltage has lethal potential, and the CRT's can have capacitive storage of it, even if the unit IS OFF! Seek a qualified service person to help you!
Posted on Nov 26, 2013
3 Suggested Answers
TVtechmaniac
  • 140 Answers
SOURCE: Picture "jumps" at startup for about 20 minutes until warm.
You have some leaky filter caps. They are: C2C52 = 10 MFD 50 VOLT (off the base of Q2C51 on the signal board)Also check C2P05 = 100 MFD 16 VOLT (off pin #3 of IC2P01 on the signal board) and C2P03,C2P08 = 100 MFD 16 VOLT both on the signal board.
Posted on Sep 07, 2007
SOURCE: Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Posted on Jul 30, 2008
Perm Press cycle only runs for 2 min. and jumps to 14-15 min. every time.
find your manual and read it . sounds like the cycle has a 12 to 15 minute limit .
Feb 14, 2016 | Samsung DV330AE Dryer
Pickup coil?
sounds like you need to clean out the carb. or you have the wrong gap on the spark plugs. having to jump start it i would start with the spark plugs gap. gap open to much will take a bit of starting. and when engine is at running temp. it use less fuel and the spark plug gap gets bigger. until there is no spark or not a good one to keep engine running.
Jan 22, 2014 | 1991 Honda Civic
Purple static lines and a jumpy picture
Your picture tube is about to go.
If it's still under warranty,take it back.
Hope this helps.
Nov 26, 2013 | Mitsubishi VS-45607 45" Rear Projection...
My tv picture jumps when I walk by it. Is it the
It is EMI ... electromagnetic interference...
Do you carry your cellphone when this happens? Maybe your iPod?... could also be static charge on your clothes (not likely, but possible)... like wearing sox on a carpet...
Please comment for further help...
Sep 09, 2009 | Televison & Video
Alarm problems
When creating a new alarm, the LG Shine will start with the "Set Time" function where you can set a 15 minutes alarm jump (by moving the navigation button horizontally). If not desired, you can go one step down onscreen to set the alarm time manually. If you accidentally jump back to the 15 minutes jump method in the previous function, it will automatically postpone the alarmsetting with 15 minutes increments again. Please verify you don't use that function by accident while setting up the alarm time manually. If all of this is not the case, I would suggest to return the phone because there could be a problem with the phone or software.
Feb 06, 2009 | LG Shine KE970 Cellular Phone
DVD picture jumps -- doesn't track
the lens is bad buy a lens cleaner.
Jan 10, 2009 | GoVideo Go Video DVD/VCR Combo
Picture jumping
If this jumping is accompanied by a sharp snapping sound, it may be the high voltage circuit discharging to chassis. Leakage can cause the jumping and a discharge can momentarily blank the picture.
If you want to try a 'cleaning cure,' I suggest you pull the plug (not just turn it off) for several hours, preferably overnight. Sets of this size can carry enough static charge to punch a hole through your thumb if you get careless.
Remove the rear housing (shouldn't be more than 6-8 screws) and using a clean paintbrush, and possibly a vacuum to **** up the dust, clean it well and pay special attention to the area around a largish misshapen black plastic object bigger than most anything else and connected to the back of the picture tube via a fairly thick cable.
Dec 09, 2008 | Televison & Video
S class
you can jump directly to the battery. the procedure for doing this is as follows connect the positive cable to the dead vehicle(yours) then connect the ground cable either to the battery or to the engine block. then conect the positve cable to the jump vehicle then connect the ground. start the jump vehicle and rev engine to 1500-2000 rpm for 2 minutes. let vehicle idle for 5 minutes. then try and start dead vehicle. sometimes the whole thing takes 10 to 15 minutes to be successfull. please rate the solution.........thanks
Sep 24, 2008 | 2000 Mercedes-Benz S-Class
Going down fast
Its definately fixable. Can you post a picture of what your refering to when you say horizontal lines and jumping? Also do you have any soldering ability or troubleshooting experience? Let me know
Jan 12, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi WD-62825 62" Rear Projection HDTV Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
