Question about GE Refrigerators
GE profile fridge freezer antarctica will not stay cold. Freezer stays about 4 degrees and fridge at 43 degrees.
aasc
  • 1606 Answers
SOURCE: our freezer on our ge profile side by side is not staying cold
Pull the refrig out from the wall . Behind it you will see an 8 " X 10 " panel , held on by several screws . Unplug the refrig and remove the panel . On the control board , you will see a blue plug with 3 larger wires going to it . Unplug this plug . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . Get a short piece of insulated wire with both ends stripped about 1/4 " . Insert one end into wire2 and the other into wire3 . Plug the refrig back in . Open the freezer door and , at the bottom of the rear panel , do you see a red glow ? If no glow after about 1 min , then the defrost heater is probably bad . To replace this , you would have to remove the rear freezer panel , and under the coils , will be a glass tube . This is the heater . If you do see the red glow , then either the board or the #4 and #5 thermistor are bad . Start with the thermistors . Small 1" white cylinder , with 2 white wires going to them . One is clipped on top of the freezer coils , and the other is at the bottom of the freezer panel , inserted into a holder . These thermistors , tell the board the temp of coils , and freezer .
Posted on Sep 20, 2009
  • 16 Answers
SOURCE: GE Profile Freezer not cold enough
VACUMM THE COILS UNDERNEATH THE THE FRIDGE THEY MAY BE CLOGGED WITH LENT AND DUST...... HOPE THIS HELPS
Posted on Jun 10, 2009
SOURCE: GE Monogram will not accept freezer/fridge
My ge monogram gets warm every year this time of year. All of a sudden no ice and everything defrosts. We vacuumed vents up top last yr and it got cold again. What the heck???
Posted on Aug 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Our refriderator (GE Profile) keeps losing its
With a Profile the problem is most times the defrost heater has burned out.I have yet to see the control board be the reason. Look into rear of freezer on rear panel if not defrosting it will have a frost line creeping up the panel wall. The defrost heaters for your model have glass tubes surrounding the heating element and most times one you get the ice melted away yo can see black marks inside glass where it burned out. So if you want to do this yourself unplug and remove the rear panel and defrost with a hair drier to speed things up. It may take about two more days before this begins so plan on saving all you can somewhere else. I know, yea right! Anyway things could be worse. I will list the parts you will need and contact info, Thanks Sea Breeze
Posted on Apr 11, 2010
woodchuck789
  • 4059 Answers
SOURCE: Freezer is cold, fridge is warm; replaced main board already
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Apr 25, 2010
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
The temperature is set correctly but the top portion of the refrig does not stay cold (and goes up to 60 degrees) while the freezer gets too cold (and goes to -11). We cleaned the vent on the motor and...
Sounds like the ductwork inside the fridge that connects to the freezer is either partially blocked with ice or the damper flap is stuck in that duct.Please let me know if this helps, a good defrost should cure it if it is
Jan 19, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
The refrigerator will not stay cold set @ 37 and it runs and the freezer is -4
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 22, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
My GE profile side by side refrigerator's temperature is not staying where I put it. It keeps popping to 31 degrees when I set it for 37 degrees. My food is freezing !!
It may need to defrost. Shut it off for 4-5 hours to let any accumulated ice to defrost and see what happens.
There also is a control that directs more cooling to the refridgerator or the freezer compartment. It may need to be readjusted. It will take 24 hours to stabilize.
Oct 20, 2009 | Refrigerators
Ge profile Ps27sgra refrigerator and freezef are
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Jun 10, 2009 | GE Profile Stainless Bottom-Freezer...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
500 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
