Question about GM Chevrolet suburban lens. courtesy/dome/reading lamp. dome lamp
Change a reading lamp
How do you change a burned out reading lamp
    Master:
  • 560 Answers
The lens cap will pop off with slight pressure on one of the sides.
Posted on Jul 27, 2014
Samsung HL-R5688W DLP TV Screen Burn
I don't know where you got the information that burning could not happen but that is completely wrong. If it is a monitor, tube tv, LCD/LED, DLP or any other kind of viewing device it can burn. With that out of the way if the lamp warning is coming on then it is time to replace it but your image problems are deeper than that. The screen appears to be separating. By that I mean there are three layers and sometimes more depending on the manufacturer that display color. Think of it like saran wrap laired on top of each other. As they get old or of poor quality they start to separate and show some pretty funky imaging. Without the TV in my shop I most certainly cannot 100 percent say for sure that this is it but I would strongly consider this as not fixable.
Mar 02, 2014 | Samsung HL-R5688W Type 2 Compatible TV...
I want change my headlights
WOW NO YEAR CAR>? 1973 ??????
do tell what change means.
my stock head lamp is dead and burned out
i want to replace it with new stock lamp. (spec lamp)
or upgrade it or modify it some way.
change has no meaning. not really.
if this is just normal service ,why not read that page in operators guide
here they are,
free
RTM
http://justgivemethedamnmanual.com/honda/honda-civic-sedan-owners-manuals/
if yours is not here, then post year car.
and body type as you can see ,bodies vary.
Feb 17, 2014 | Honda Civic Cars & Trucks
Low fuel light on gauge doesnt work
lamp burned out, ?
but does the fuel guage work 100%
and at what tank level do you expect the lamp to come on.?
did you read the FSM on this, its covered
or alldata.com?
free.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
on this car, the PCM reads the fuel level then sets the fuel guage
and if the level (voltage from tank sender) is below a specific
voltage , it glows the lamp, low fuel
so if the fuel guage works, and the lamp is dead, the lamp is burned out. (or conn. bad to it)
Jan 24, 2014 | 2002 Jeep Wrangler
How to change bulbs in a safescan 65
read your owner manual section troubleshooting or how to replace it.
God bless you
Rear-Projection TVs have a lamp, which picks up the picture and projects it on the TV screen. A burned-out or connected lamps are two of the most common problems for Rear-Projection TVs. First, you will want to confirm the bulb is still good. If the bulb is bad then then replace it immediately. Second consult your user manual and verify the lamp and lamp cover are installed properly. Most Rear-Projection TVs have warning light which notify you when there are lamp problems. Again consult the user's manual to see what each light means.
Nov 03, 2013 | Televison & Video
Funtional code SC101-00 appears on Lanier 5245 copier when turned on. Exposure lamp is burning.
Hello!
There you are. You asked the question but you already know the answer.
The exposure lamp are burned so... this error code appears in the display.
You need to change the exposure lamp
Sep 10, 2011 | Ricoh Aficio 450 Copier
Bulb blew, now cannot turn off any bulb
the lamps are controlled by a triac that is probably mounted on the control board ... its not unusual for light bulbs to draw extremely high currents as they burn out ... thats because the melting tungston forms a plasma that arcs at very high current levels until a fuse or lead wire burns off inside the lamp ..thats why you see such a bright flash as they burn out .. ..as i recall lamps of 60 watts or greater have to have a built in fuse in the base ... lamps of lower wattage are not forced by law to have that .. so when they burn out they can easily damage external electronics .. so your problem is a shorted triac .. thats a transistor like device that is often used for lamp brightness control .. you can replace the entire control board $$$ or just the defective triac (like $2) .. the bad triac will read shorted between main termanals 1 and 2 on an ohm meter ...(power off of course) .. a normal one will read open ... its likely soldered in place and may have a heat sink attached ... thats an easy job for an electronic person ..
Aug 18, 2009 | Jenn-Air JXT8136ADS Kitchen Hood
Change the bulb in the courtesy reading lamp?
if this is the light you push up on to turn on and off you use a small screwdriver and pry it down. it is held by 2 plastic pins that snap into holes.
Jun 25, 2009 | Dodge Caravan Cars & Trucks
VT440 NEC PROJECTOR
let it cool down then remove the lamp and see if it looks shattered or burnt- if it is you have solved your problem-change lamp!
May 27, 2009 | NEC (50019497) Projector Lamp for VT440,...
How to change lamp on Hitach 60vg825
Yes, you are due for a lamp. Save yourself some money by ordering just the bulb p/n UX21516 (instead of the whole lamp assy), install it yourself. There are lots of us that sell these bulbs far below what the assy costs. Make sure it is an OSRAM bulb though.
Dec 31, 2007 | Hitachi 60VG825 60 in. LCD Television
GM Chevrolet suburban lens. courtesy/dome/reading lamp. dome lamp Logo
832 people viewed this question
Top GM Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a GM Hardware and Accessory Expert? Answer questions, earn points and help others
