Question about Hayward H Series Millivolt 250,000 Btu Pool Heater H2501
Hayward H250 (millivolt) pilot won't stay lit
I can get the pilot to light and stay lit as long as I keep the gas control knob depressed. As soon as I let the control knob up the pilot goes out.
Any help appreciated!
Dale
  • 116 Answers
Make sure the flame hits the thermo couple if so then replace it lows has them in the water heater section thermo couple gets hot makes millivolt signal then opens gas valve
Posted on May 09, 2009
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
My Hayward h250 Millivolt heater won't stay on. If I jump the "TH" connections I can get the main burners to come on, once I remove the jumper, the main flame goes out. I replaced the pilot assembly and...
you prolly have an electrical short somewhere. follow the circuit and if any safety is getting around 200-250 dc millivolts then theres the problem. otherwise you have an open safety switch, or tsta controls
Aug 07, 2013 | Hayward H Series Millivolt 250,000 Btu...
How do i light the pilot light for the hayward
The lighting instructions are usually located inside the heater on the inside of the access panel or on the firewall near the gas valve.
Most millivolt heaters require you to turn the gas valve knob to the pilot light position and then depress the knob while lighting the pilot through the pilot hole. This varies depending on the exact model.
Aug 07, 2012 | Hayward 250 1 Millivolt Propane Pool...
I have a hayward H250 and the pilot lites easily and quickly as long as the gas control knob is depressed on "pilot" as soon as the knob is released to switch it to "ON" the pilot...
This is definately hands down a bad thermocouple. The thermocouple sits at the bottom of the burner tray. You will need to remove the nut secureing the pilot assembley and remove the wires.. I will post a link to the manual for this heater below so you can look at the parts diagram to find the thermocouple placement if neccessary. It will also have the part number so that you can order it.
Note: thermocouples can be generic and purchase at a local HVAC or pool/spa retailer.
Refer to page 28 for a diagram of what the pilot assembley looks like. The thermocouple is here in figure 46. Written Instructions for removal of the pilot assembley is on the bottom right of page 28 as well.
May 16, 2011 | Hayward H Series Millivolt 250,000 Btu...
Unit dosn't seem to bve sensing flame. Clean your flame sensor. Its connected to your pilot light assembly usually. Its a metal rod that sits inside the flame. Could also be bad and need replaced. Hope this helps.
May 16, 2011 | Heating & Cooling
Cannot tell where pilot, on or off is on gas valve
I assume you have a W-R and should see a small notch down around 5 o'clock or so. That position is where you depress the knob to light the pilot.
Jul 03, 2009 | Hayward H Series Millivolt 250,000 Btu...
Pilot will not stay lit after button release
most likely you have a thermopile that has low output. it takes about 100mv to maintain pilot light
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Heater won't stay lit
On your main gas manifold you have orfaces that screw into it at each burner. Remove these and see if their are small spider webs in them. They will look like little lint balls. They can keep your main burner from getting gas and in turn keep the heater from sensing flame. The pilot lights and the heater starts but no flame at the main will shut it rite down. See if this helps.
May 05, 2009 | Hayward H Series Millivolt 250,000 Btu...
Hayward H Series Millivolt 250,000 Btu Pool Heater  H2501 Logo
1,190 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
