Question about Water Pik New Waterpik Wp 360w Cordless Dental Jet Oral Irrigator
Recharged and won't pump water tvrough the tip
Waterpik will not pump water through the tip after rechaarging
Waterpik stop pumping water. Can it be fixed. Have used it for a few times.
Perhaps - the issue has to be with the motor or the pump . Identify the culprit and take corrective action.
Sep 03, 2017 | Home
How can I repair waterpik flosser ultra 110v that I have accidently put in a 220v?
According to this suggestion, replace the resistor (47 Ohms).
https://www.youtube.com/watch?v=_J7_rV7ui1Y
Mar 09, 2016 | Waterpik Personal Classic Water Flosser...
What bottle brush do you use to clean a Waterpik SWI 615 Sinusense Water Pulsator?
Any bottle brush will do if it fits into the unit to do the job. If the bristles are polyester or another kind of plastic it will not absorb bacteria. Wash and rinse the brush well after use and don't use it for anything else.
Jul 27, 2013 | Waterpik SWI 615 Sinusense Water Pulsator...
Is the Waterpik Ultra Cordless Dental Water Jet WP450 good for sensitive gums?
The Waterpik Ultra Cordless Dental Water Jet WP450 has pushbutton dual-pressure control system with low for sensitive gums (as well as high for deep cleaning).
Apr 29, 2013 | Health & Beauty
Waterpik shower head leaks
Thread grip, meaning plumber's tape? Water Pik leaks on the end large circular sprayer part.
Feb 05, 2012 | Water Pik Waterpik Power Spray Shower Head...
I have the older waterpik. In an attempt to change my hose, I took the unit apart. After changing the hose, I cannot seem to turn the unit on...it appears the the on/off switch is locked.
I just ran into the same problem after disassembling my waterpik. I have a problem with the device not pumping water once powered on. It siphons just fine with power off, so I'm puzzled as to why it quit working 1 use after not using it for a long time.
I finally solved the switch problem at least: Before you attempt reassembling the top to the base, gently pry the switch cap prongs inwards until the cap pops loose. THEN assemble the top and base. Once done, align the switch cap with the internal plastic slide that activates the switch, and pop the cap into place. That should solve the issue.
Sep 13, 2011 | Water Pik Pik WP 60W Oral Cleaning System
Replacement cord for dental irrigator
You did not specify, I hope you are talking about the TRS-559 or TRS-553. Both come with a lifetime warranty, go to waterpik.com or call 1-800-525-2774
Mar 14, 2009 | Water Pik Waterpik& Elements& Handheld...
Water Pik New Waterpik Wp 360w Cordless Dental Jet Oral Irrigator Logo
Top Water Pik Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Water Pik Health and Beauty Expert? Answer questions, earn points and help others
