Question about Kenmore Elite HE4 Electric Dryer
Dryer won't start
Purchased a kenmore elite he 4t front load dryer. it won't start.  it gave me a biot of trouble this morning and only wanted to start in normal cycle.  i had to hold the button down for about 15 seconds to get it to respond.  I was able to adjust the time of the load but no other button would respond.  not it is not starting at all.  it must know that the warranty just expired!
I checked the circuit breaker--unplugged the unit for 2 minutes (thought that it might reset like some other electronics with a computer-brain--nothing seems to work
  • tony1980 Oct 09, 2008
    we have a kenmore dryer. when you set the timer you can hear it clicking but the dryer will not start. i replaced the start switch and that didn't work.
  • Anonymous Mar 16, 2014
    When using the "timed dry" cycle we can no longer adjust the time". It is stuck on 10 minutes and does not come on with the default 40 minute setting. I don't think there is a problem with the + and - touch pad because we can adjust the time up and down in both the "rapid dry" and the "custom refresh" cycles. I have unplugged the unit reset the circuit breaker in an attempt to reset the unit but nothing resolves the issue.
Wiggle, jiggle and tap the damp dry button.  It gets stuck and the whole machine shuts down.  Tap the normal cycle or what ever setting you want inbetween and it will turn back on.  Mine did this and I paid for a service call $113. for him to clean the damp dry button with rubbing alcohol.  It has been stuck since.
Posted on Oct 12, 2007
  • 447 Answers
It sounds like you do need either the main computer or the the console electronics. Sorry there is no other reset of any type.
Posted on Oct 10, 2007
Kenmore oasis elite dryer trouble shoot f-24 error kenmore
According to the manual, follow these steps:
  • For an "F" error on your Washing Machine.
  • Select PAUSE/CANCEL twice to cancel the cycle.
  • Select DRAIN & SPIN if there is excessive water in the washer.
  • Re-select cycle and press START.
  • If the problem remains, call for service.
Here's the full manual: Kenmore 110.45986400 Owner's Manual
Jun 15, 2014 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 4t Elite Front Loader Washing Machine
Inside the dispenser drawer, at the bottom there is a tab that you can push down to remove the dispenser drawer. Remove the drawer and check if the dispenser holes are clogged, this is a common cause.
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Why the control locked is on , i have a kenmore elite HE 4t washer can't do nothing to make it go away so won't let me make a wash
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 10, 2010 | Kenmore Elite 45986 Front Load Washer
HE 2plus washer won't turn on
is it not draining. more than likely you need to clean your pump catch. take the bottom panel off you will see the catch untwist. lots and lots of water is going to come out be prepared
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
F11 CODE
you have bad communication ,,between the control board and themotor control board..,,check for a lose harness at booth ends
Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
New Kenmore Elite Front Loader will not get past 'Sud' cycle,
Hello wheeljc; I had the same problem when I purchased my Kenmore Elite in 2006. I have a HE4t front load. It's possible that you're using to much detergent, if you're using HE liquid it only requires a small amount and does a very good job.
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Dryer displays PF when start button is pushed
might want to have a electrician check to make sure its not dropping neutral
Aug 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kemore elite HE 4t blinking H and F displaying
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Please follow the recommended tips and let me know if you still require assistance. I hope this helps you.
Aug 28, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
154 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
