Question about Cisco SPA502G IP Phone
Cisco spa502g ip address is 0.0.0.0
Initializing network
4 Suggested Answers
SOURCE: Cisco 7960G IP Phone Problem
Try to manually reset the phone - **#"Settings" (this will unlock the configuration) + Network + menu under number "33" - erase the configuration. Then the phone configuration will be erased. Also you can manually set IP address and TFTP server
Posted on Jun 10, 2008
  • 3 Answers
SOURCE: Restore factory settings Cisco SPA502G
Press Menu button and chose Factory Reset.
Posted on Nov 15, 2012
  • 3 Answers
SOURCE: how can i change the
Through menu:
Network -> WAN connection Tupe - Static -> Current IP - Enter New IP.
Or by web or in DHCP make reservation for your Phone's MAC address
Netgear fs516 default ip address
switches do not normally have ip addresses as they are layer 2 network devices. They work on the MAC address of each network card attached to it to direct the network packets of data to the correct Network card.
Cisco Switches have an IP address but it is a virtual ip address used to remotely log into a Cisco Switch via IP but has nothing to do with the switching function however this is not a cisco switch.
Routers have IP addresses and use them to switch IP addressed packets to other Networks that have Routers connected to Switches.
Jun 30, 2014 | NetGear FS516 Networking Switch
My Cisco SPA502G does not ring for incoming calls
It is a problem with the router. if you assign it a public ip adress it will stay on line the other option is a router that will allow consistent nat translation
May 12, 2014 | Cisco SPA502G IP Phone
Two routers, two WAN links
easy...
CODE
!R1
interface GigabitEthernet 0/0
ip address 172.16.1.1 255.255.255.252
ip ospf network point-to-point
bandwidth 100000 ! Makes OSPF think its 100Mbps
interface GigabitEthernet 0/1
ip address 172.16.2.1 255.255.255.252
bandwidth 10000 ! Makes OSPF think its 10Mbps
router ospf 10
network 172.16.1.1 0.0.0.0 area 0
network 172.16.2.1 0.0.0.0 area 0
network 10.1.1.1 0.0.0.0 area 0
passive-interface GigabitEthernet0/0/0
!R2
ip address 172.16.1.2 255.255.255.252
ip address 172.16.2.2 255.255.255.252
router ospf 10
network 172.16.1.2 0.0.0.0 area 0
network 172.16.2.2 0.0.0.0 area 0
network 10.1.2.1 0.0.0.0 area 0
This will make your wireless link preferred, if the link fails the OSPF adjacency will fail and routing will fallback to the other link.
You should ideally have some /32 loopback interfaces so the router will use this as the OSPF RID, or manually set the RID under the OSPF process.
More discussion about this you can see http://www.router-switch.com/forum/showTopicDetails/11/490
Apr 12, 2013 | Cisco Computers & Internet
How to recovery from boot loop?
Are you familiar with wireshark or other packet sniffers? You might consider running wireshark on the network to see exactly what the phone is doing when it boots. It might be configured to connect to a TFTP server or something on boot, to look for a firmware or config file update.
Cisco Telephone Power Supply
Nov 14, 2012 | Cisco SPA502G IP Phone
Apr 05, 2012 | Cisco SPA502G IP Phone
Hard reset spa502g
Press Menu button and choose "Factory Reset".
Nov 09, 2011 | Cisco SPA502G IP Phone
How can i change the ip address of SPA502G? THANK YOU FOR YOUR HELP
Through menu:
Jan 25, 2011 | Cisco SPA502G IP Phone
Change IP address of Cisco 1841
once in enable mode, goto config mode. then select interface, i.e. f0/0 and then type in the following:
ip address x.x.x.x y.y.y.y where x is your IP address you wish to have and y is the subnet mask
example below:
router#config t
router(config)#int f0/0
router(config-if)ip address 10.0.0.1 255.255.255.0
hope this helps!
Oct 28, 2009 | Cisco 1841 Router
Pix 515E inside to outside translation problem
Dear Kiran,
What is the name assigned for isp 1 as well as isp2.
for your reference kindly find the sample configuration......
ISP 1:
interface ethernet 0 100 full
nameif outside security-lvl 0
ip address outside 203.193.129.132 255.255.255.240.
nat (inisde) 1 (local network)
global (outside) 1 203.193.129.133
route outside 0 0 203.193.129.129.1.
regards,
mani.S
Mar 09, 2009 | Cisco PIX 515E Firewall
Switch install help
Sorry about your Admin.  With Cisco this is NOT an easy task.  Did the admin have ANY documentation on the network?  Do you have VLAN's? The IP's are set by the Admin after he figures out what is next in line for the configuration HE setup.  If its setup DHCP, that means a server will figure the IP for you, but for that to work it has to already be setup across your network.  Go into the cisco router already setup and see whats going on there.  To get in you will need passwords probably 4 if setup in a typical Cisco manner. go to this link it will help you get started: http://www.fantek.org/cisco/wpbascom.htm
be careful what you undo, you can bring down part or all the network or the internet connections.
now you know why cisco people get payed the big bucks...good luck to you
Oct 12, 2007 | Computers & Internet
Cisco SPA502G IP Phone Logo
126 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
