Question about Cisco SPA502G IP Phone
Cisco spa502g ip address is 0.0.0.0
Changed my work desk and now phone shows ip 0.0.0.0 and phone not working
SOURCE: Ethernet Disconnected message in POE 7941G IP Phones
the first problem will be to check or replace the cable that you use to connect the phone or check the jack that you use
Posted on Jul 12, 2007
fcollingwood
  • 58 Answers
SOURCE: Inline power problem: cisco ip phone 7941G
You need to ensure that each port that has a phone plugged into it is configured with power over ethernet configured switched on.
Posted on Mar 21, 2008
SOURCE: Cisco 7912 sip phone
Can you please make sure that you can ping the device - you might have a routing problem
Posted on Jun 09, 2008
SOURCE: Cisco 7960G IP Phone Problem
Try to manually reset the phone - **#"Settings" (this will unlock the configuration) + Network + menu under number "33" - erase the configuration. Then the phone configuration will be erased. Also you can manually set IP address and TFTP server
Posted on Jun 10, 2008
SOURCE: 7910 IP Phone
you stupid ****! it needs a voice vlan
Posted on Jan 13, 2010
My Cisco SPA502G does not ring for incoming calls
It is a problem with the router. if you assign it a public ip adress it will stay on line the other option is a router that will allow consistent nat translation
May 12, 2014 | Cisco SPA502G IP Phone
How to recovery from boot loop?
Are you familiar with wireshark or other packet sniffers? You might consider running wireshark on the network to see exactly what the phone is doing when it boots. It might be configured to connect to a TFTP server or something on boot, to look for a firmware or config file update.
Cisco Telephone Power Supply
Nov 14, 2012 | Cisco SPA502G IP Phone
Restore factory settings Cisco SPA502G
Press Menu button and chose Factory Reset.
Apr 05, 2012 | Cisco SPA502G IP Phone
Hard reset spa502g
Press Menu button and choose "Factory Reset".
Nov 09, 2011 | Cisco SPA502G IP Phone
Cisco ip phone 7912 is not working. when conecting in LAN then it will not boot, while another same series ip phone on that LAn port works perfectly. Only red and green LED blink continue in...
If it is getting an IP address, goto that IP address and there you will be able to see some console messages. See if alternate TFTP is set and is going to a different CM server. If so change it to the ip of your CM.
Aug 17, 2017 | Cisco 7912G IP Phone
How can i change the ip address of SPA502G? THANK YOU FOR YOUR HELP
Through menu:
Network -> WAN connection Tupe - Static -> Current IP - Enter New IP.
Or by web or in DHCP make reservation for your Phone's MAC address
Jan 25, 2011 | Cisco SPA502G IP Phone
Hi,i wanna use cisco ip phone 7940 as sip ip phone.when i power up the phone ,it can get ip from network,but finally,it shows "TFTP timeout"in display led.All the buttons can not be used.What...
the DHCP server should be providing the address of the TFTP Server as DHCP Option 150. The most likely problems are:
Option 150 not defined, or not the correct IP address of the TFTP Server.
Or possibly your TFTP Server is not functioning properly.
If you have not Option 150 defined, the phone will use the default gateway as the TFTP server address.
Cheers, Simmo99.
Dec 29, 2010 | Cisco 7940 IP Phone
Change IP address of Cisco 1841
once in enable mode, goto config mode. then select interface, i.e. f0/0 and then type in the following:
ip address x.x.x.x y.y.y.y where x is your IP address you wish to have and y is the subnet mask
example below:
router#config t
router(config)#int f0/0
router(config-if)ip address 10.0.0.1 255.255.255.0
hope this helps!
Oct 28, 2009 | Cisco 1841 Router
Pix 515E inside to outside translation problem
Dear Kiran,
What is the name assigned for isp 1 as well as isp2.
for your reference kindly find the sample configuration......
ISP 1:
interface ethernet 0 100 full
nameif outside security-lvl 0
ip address outside 203.193.129.132 255.255.255.240.
nat (inisde) 1 (local network)
global (outside) 1 203.193.129.133
route outside 0 0 203.193.129.129.1.
regards,
mani.S
Mar 09, 2009 | Cisco PIX 515E Firewall
Sep 11, 2007 | Cisco 7940G IP Phone
Cisco SPA502G IP Phone Logo
70 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
