Question about Sharp Televison & Video
Give model # flyback transformer SHARP primo 21''
sharcnet
  • 2130 Answers
SOURCE: Toshiba flyback transformer
Try MCM Electronics. Try this link:
http://www.mcminone.com/search.asp?keyword=flyback
You can also call them at: 1-800-543-4330 They may be able to help you find the one you are looking for or offer a substitute.
When I owned a repair center several years ago, I ordered flybacks and other parts from them and never had a problem.
Good Luck!
- Jim
Posted on Jan 22, 2008
  • 298 Answers
SOURCE: SHARP MODEL 27N-S100
This company can supply it to you.
Sharp 27NS100 Flyback Replacement
Posted on Jun 19, 2008
ladywinn
  • 5138 Answers
SOURCE: Replaced Flyback Transformer and Horizontal Output Transistor
I am proud to see you got your set working Good job!
Posted on Aug 26, 2008
Rifaa
  • 99 Answers
SOURCE: MY SHARP PRIMO TV MODEL 20V L75M IS ASKING FOR A SECRET NUMBER
It may be a parental lock, so u need the code or u have to reset it, check the manual on how to reset it
Posted on Jan 08, 2009
Demonic-2011
  • 472 Answers
SOURCE: sharp tv primo 21`inch turn on red light only
The most likely probable causes of the 'red standby light only - no other function' problem would be the flyback transformer/horizontal output transistor or a shorted component on the HT rail, which derives most of its voltages from the power supply so check this area as well.
If the power supply checks out all OK, I would advise replacing the horizontal output transistor and flyback transformer.
Be sure to get the correct transformer type for your model when replacing it, as each one has different characteristics (including voltage rating and EHT output) in relation to the picture tubes they are connected to. Some may have focus and screen controls as part of the transformer itself, while others will have this as a separate part.
Posted on Feb 16, 2011
I HAVE SHARP COMPANY 21 INCHES CRT MY FRIEND TV SET PROBLEM IS SET DEAD IN POWER SUPPLAY TRANSISTER 1886 REPLACED AFTER POWER SUPPLAY IS OK FBT ARCKING THEN IMMEDIATLY SET SWITCH OFF SET IN CIRCUIT R6
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 21, 2014 | Sharp Televison & Video
14V- WISON crt sharp tv no display how fix it
If there has sound but no pic...Check those bad resistors around the Flyback transformer, or its causing that the Flyback transformer is poor.. rejuvenate FBT.
May 19, 2014 | Sharp 21B-S10 21" TV
Image not focused
Possible worn out tube. The focus adjustment is on the flyback transformer and has to have the back cover removed to access it. The flyback will be a black and have a red wire connecting to the crt tube. This is very high voltage and can be dangerous. With a plastic screwdriver you can turn the focus adjustment knob on the transformer. Do not adjust the screen control knob. If the focus does not clean up, then the tube is probably worn or the flyback is bad.
Nov 27, 2013 | Samsung SyncMaster 1100MB 21" CRT Monitor
Sharp primo 20v l75m flyback number?
Download its repair manual by internet. It has all details. It is in PDF format, and cannot send to you by this window.
Mar 26, 2013 | Televison & Video
Flyback no. of cmt 2198
The B+ of your CMT 2198 TV seems to be about 95V.
• Have a time to read about these tip:
How to test Flyback Transformer Without taking it off the Board
While we search for your flyback transformer T751 part number
we will let you know.. .
Jul 31, 2012 | Hitachi CMT-2195 21" TV
My 26" 1997 Sharp T.V. model #25H-M60 turns off by itself and won't turn back part of the time.
First thing if you are able is to unplug set and remove rear cover (lay set face down on a padded surface).
entire main board should be able to be seen or released so it slides out--take a very careful look at flyback and rest of board for any cracked or bad solder connections.
One bad connection (age) can cause this.
5_21_2012_3_10_50_pm.jpgtypical high voltage transformer which is also called a flyback transformer.
May 20, 2012 | Sharp 32L-S400 32" TV
Sharp tv primo 21`inch turn on red light only
check your horizontal transistor maybe it's shorted replace horizontal transistor or maybe the fusible fuses are open check for open resistors at the horizontal section of the circuit.
Dec 22, 2010 | Sharp Televison & Video
Hitachi model CMT-2928 Serian Number GIK 000287 after turn on the television around 5 second screen become flicker like have thunder.please help for this issue to solve thank
do you smell something at the back of your tv. if yes and still hearing the continues cricking sound its your flyback transformer it has a leak a high voltage current is arching try to replace the flyback transformer.
Oct 15, 2010 | Hitachi CMT-2195 21" TV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
