Question about Whirlpool EL7ATRR Refrigerator
I have a Whirlpool refrigerator, model #ET8CHMXKQ0, manufacturing date 07-03. I think the fan is running but it's not cooling. The fridge is not cool and the freezer is cool but not not freezing (e.g. ice is melting and new ice is not being made). Any ideas?
  • Anonymous May 20, 2009
    Same - the freezer seems to be dead but the fridge appears to be working.
  • 18 Answers
SOURCE: Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
Posted on May 29, 2009
heavyice
  • 374 Answers
SOURCE: refrigerator & freezer do not cool
First check if the Compressor of the Fridge is working.There is slight chance that the compressor is working but the pressure of the compressor is low or the gas might be less.Check the compressor if there's oil on it's pipes...it means that there is a leakage n needs gas refilling.
Posted on Jun 07, 2009
  • 363 Answers
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Posted on Jul 28, 2009
aasc
  • 1606 Answers
SOURCE: whirlpool refrigerator stopped cooling. the
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
Posted on Nov 13, 2009
  • 77 Answers
SOURCE: Cat number ED25TEXHW00, side by side, Whirlpool
If the compressor will not kick on what you have is either a bad compressor or a bad starting device. Generally the unit will try and start and after 8 seconds or so you will hear a loud tick. That indicates the relay is bad. If the compressor is bad it will usually make a loud humming noise.
The start device is plugged into the side of the compressor. Unplug the frig. You can simply take off the wires to the start device (remember where they go!!!!!) and pull it off. You have two piece, the overload and the relay. The relay is the piece that is most likely the problem. Some machines will have these put together in a white plastic block. You can shake this entire piece and if you hear loud rattling it is broken. Sometimes the relay is visibly burned and blacked where it plugs into the compressor. Anyway, if you do not have this white plastic relay/overload combo, the relay is a brown square shaped plastic piece. Shake it and see if you hear rattling. If not, chances are very good the relay is ok, and the compressor is locked up.
Compressor changes are expensive and unless the frig is extremely nice and cost a pretty penny, they aren't worth fixing. Relays and overloads should not break $100 for the parts, and any tech should be able to change one in under 10 minutes. So if it's a relay fix that puppy! good luck :D
Posted on May 30, 2010
Should the fan operate all the time in my refrigerator
Most of the time it runs only when the compressor is running. In other words compressor and fans will run together when the fridge thermostat ask for cold and stops together when thermostat is satisfied. In newer fridges some time inside fan (evaporator fan) might PERIODICALLY run without compressor to circulate little cool air to fridge compartment from freezer compartment.
Sep 30, 2014 | Whirlpool Refrigerators
Need the Technician Repair Manual for a Whirlpool Stand Alone Refrigerator Model#EL87TRRRV00 Where can I find said text ?
at the bottom of your fridge in the back there is a cover with 4 screws across the top and 3 across the bottom. remove the cover and you will find the evap fan. try this link. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5132691&diagram_id=29290087#d29290087
Sep 04, 2012 | Whirlpool Refrigerators
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
I have a Whirlpool fridge that is not cooling. I have done the following 1. Turned the thermostat to zero and then started it again after 30 min wirks for some time and then stops again 2. Opened the...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 23, 2011 | Refrigerators
My whirlpool fridge makes a loud humming noise when the door is closed. It is not freezing items in the freexer and is not cooling items in the fridge section. The freezer is above the fridge section in...
The fan is hitting ice build up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 11, 2010 | Whirlpool Refrigerators
Hi I have a whirlpool fridg. m/n ET19RKXGN00, S/N EH1230820 with a MFG date of 03/98.It's a top freezer model and I have water dripping from the top of the fridge.almost all the time. I removed the plastic...
The last tip will help you out there...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 16, 2010 | Whirlpool Refrigerators
Fan in freezer pqrt of fridg Model #ET18NKXDW serail # EF0722540 making noise on and off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There could be ice built up and hitting the fan or the bearings in the fan could be going bad...
heatman101
Sep 12, 2010 | Whirlpool Refrigerators
Fridge not cooling
Most of the time on a whirlpool the problem is the relay on the compressor sometimes called the start device. I would replace that first. If you need help finding the part let me know. I will need the complete model # from the sticker inside the fridge section. You can look it up with diagrams at http://www3.sears.com/.
Nov 09, 2007 | Whirlpool ED5FTGX Side by Side...
Whirlpool EL7ATRR Refrigerator Logo
96 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
