Question about Honeywell RTH221B Basic Programmable Thermostat White - INC
I have a RTH 2300 digital thermostat and I installed it and it comes on fine, just won't shut off when it reaches the temperature that I set?
Could you please help me to figure out how to get it to shut off when temperature is reached?
5 Suggested Answers
  • 100 Answers
SOURCE: I have an old honeywell thermostat, non
If your thermostat has a mercury bulb it has to be level to be accurate. Check and make sure it is level. If the thermostat is level as a heating tech. i would next check the amp. draw through the thermostat so I could make sure the heat anticipator is set properly. This may be more than a home owner wants to tackle.
Posted on Nov 04, 2009
heatman101
  • 43501 Answers
SOURCE: how do I set the
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Posted on Mar 23, 2011
  • 125 Answers
SOURCE: My A/C is operating outside
With such limited information the following is the most likely problem.
1. The fan outside is running but the compressor is not.
2. The inside air handler blower fan is not working.
3. The system is froze up and not allowing any cold air to come out of the vents.
Hope this helps
Posted on Sep 20, 2011
  • 613 Answers
SOURCE: Upstairs unit will not shut off after set
Soiunds to be a faulkty Tstat or a compressor contactor welded shut.
Posted on Sep 18, 2013
Hooked the new rth 2300 with the blue yellow white green wires from the white rogers thermostat left the blue one off. nothing will come on
the thermostat is powered by 24 volt ac transformer its inside your heating unit sometimes this goes out and there is no power coming in to the thermostat check the wires with a volt meter see if you have power
Jan 29, 2014 | Honeywell Programmable Thermostat Heater
Setting start temperature on central heating thermostat
It sounds like your heating system has to little capacity to heat the home properly. 21 degrees is a reasonable temperature to expect but if the unit is running all the time and can't reach 21 degrees the heater is too small.
As far as setting the thermostat here is a link to the instructions.
http://www.salus-controls.pl/data/product/attach/rt300rf_-_eng.pdf
Nov 22, 2013 | Heating & Cooling
Adjust thermostat
A thermostat only cuts the heating off when the temperature it is set to is reached while the heating is on. If the heating is set to off then the thermostat will do nothing.
Generally you want to think about when you want your heating to come one and off by using the timer and then the thermostat is just used to ensure that you don't waste energy by exceeding the maximum comfortable temperature.
Hope this helps a little.
Nov 22, 2013 | Ovens
Digital thermostat Honeywell RTH 2300 - compressor runs when in heat mode
Check thermostat wires maybe to long and touching in the back of the thermostat
Mar 21, 2013 | Heating & Cooling
Copier won't run. it blinks the letter H and the number 4
H4 Trouble Description
The set temperature is not reached within 90 sec after turning on the power (the heater lamp lights up after 1 sec from turning on the power relay).
After reaching the specified temperature, abnormal temperature is detected.
Cause:
- Heater lamp open
- Defective installation of thermistor
- Thermostat open
Hope helps.
Sep 20, 2011 | Sharp AR-M205 Copier
The temperature on my honeywell thermostat is set to 89 degrees and does not want to change no matter what. The model is RTH2300. Please help because the heat is really unbearable.
Just google RTH 2300 for the manual, check that the hold is not on, if it is push it to turn it off, if not read thru the manual. On most stats if the unoccupied set point are blocking the occupied set points run the unnocc. temp down and then set the occ. set points down. Good luck
Jun 30, 2011 | Heating & Cooling
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
Model # RTH 1108 stopped displaying the
is my thermostat( honeywell rth1108) somehow to my attic fan. cant find a off switch for the fan. seems it is controlled by the thermostat.
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Oct 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
Honeywell Thermostat RTH 7500
In some cases the fan will keep running to remove all the heat from the heat exchanger.It can be set to run shorter or longer.You might check that out.
Mar 16, 2009 | Heating & Cooling
Honeywell RTH221B Basic Programmable Thermostat White - INC Logo
20 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
