Question about Olympus ? Stylus 500 Digital Camera
Stylus 500 flash
The flash indicator keeps blinking and does not let me take a pic. with the auto mode. But if i change the mode to no flash, it takes a picture. What can i do to sort this out
thank you for any help.
Bill
  • Jonsa Nov 04, 2007
    I have exactly the same problem with my Olympus 500. I can only take pictures if set for no flash.
    Any help appreciated.
    Jonathan.
  • swb22 Jun 09, 2008
    Have the same problem. Camera was working fine, then suddenly flash won't work, flash indicator keeps blinking and can only use camera with flash off. Battery fully charged but made no difference.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
LIkely the flash module need to be replaced. A few eBay vendors carry them. These hve been removed from working cameras and can be a cheap fix. Instakllation isn't extremly hard - but can be difficult if you don't have the small tools required. Best seek the advice of a techie friend.
early1234: use different batteries???? Geez....
Posted on Jun 20, 2008
I have the same problem. I think the flash bulb needs replacing. . . that is my only thought
Posted on Feb 24, 2008
  • 871 Answers
Hi
have you guys tried using other battery types like lithium and alkaline? if its not with the batteries, have it checked out in a service center because there might be a an issue with the charging for the flash.
Posted on Jan 28, 2008
2 Suggested Answers
SOURCE:
SOURCE: Flash indicator keeps blinking
i have the same problem. i dont think the flash is working.. i think the bulb needs replacing. i wish i knew a place to get it fixed or a place to buy a bulb...
Hp slate 500 Stylus stopped working
sounds like a short somewhere in laptop 1 easy thing to try turn off laptop no hibernate mode on the back there is a ram cover should see a little pic of a ram stick unscrew the screws reinsert ram if you able to take out put back in put screws back in turn on no difference
ok take out cd drive the screw for that is close to where the ram cover is has a little cd pic unscrew that screw gently but firmly tug or pry cd drive out look at the connector on the back see if they look like they got hot darkness colorl look inside cd bay with flash light look all around especially at the connetion for cd drive look for discoloration and smell inside and smell the back of the cd drive if it smells burnt needs to be taken apart for further inspection i rebuild laptops main killer is dust could just need a good cleaning basicly take it all apart and clean
Feb 26, 2013 | HP Slate 500 8.9 Tablet
Flash Does not work. Can only take pictures in flash-off mode
The problem you are describing is a problem with the flash charging indicator switch inside the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 30, 2009 | Olympus Stylus 410 / ? 410 Digital Camera
Flash-Off Problem
Do you have the camera in the auto mode?
Did you check to make sure that the auto focus is not in the manual mode when the flash is turned off?
If the above does not comply, call the tech support for the camera.
There is also a possibity that there is a defect, or that the flash is part of the auto focus function.
Jerry G.
Sep 15, 2008 | Olympus ? Stylus 500 Digital Camera
Camera not taking pictures
The camera may be trying to tell you that your flash is turned off in Auto mode, but to get a proper exposure you will need the flash turned on. Try turning the flash on and see if that works.
Hope this helps!
May 20, 2008 | Canon PowerShot A540 Digital Camera
Olympus µ Digital 500 flash is not working. Flash indicator keeps on blinking. But when the flash is off, the camera can take pictures. I also notice that the battery and memory card get hot when the...
This suggests the flash capacitor has malfunctioned
Check Olympus for a warranty replacement or repair cost- according to age of camera. If it is an older model a new camera may be best bet
Dec 20, 2007 | Olympus ? Stylus 500 Digital Camera
Camera only takes pics without flash
Same thing happened to me. Agreee with your conclusion. Hope someone can confirm, especially who/cost of repair. Thanks, tj
Dec 19, 2006 | Konica Minolta DiMAGE X50 Digital Camera
OLYMPUS 410
It is something that seems to be a problem with the Stylus 410s. Olympus will not repair them unless they are under warrenty, I've tried. My best advice, and what I am in the midst of myself (I have 2 of these with the same problem) is to file with the BBB. Perhaps if enough complaints come through, they will begin to fix the stylus 410 defect as they should. Good luck. =)
Oct 13, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Aug 05, 2006 | Olympus ? Stylus 500 Digital Camera
Olympus ? Stylus 500 Digital Camera Logo
74 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
