Question about Dell C1765nf Multifunction Color Laser Printer
Cant clear the paper jam
I cannot clear the paper jam
3 Suggested Answers
whitetiger93
  • 141 Answers
SOURCE: dell 924
**HW support: 877-459-7298 and you must have the Express Service Code of your printer or any Dell product you're calling in so that they can route you to the right department.** Usually, if you're having paper jams, it could be a mechanical problem with the printer. Try these: - turn off the printer. unplug the power adapter for 1-2 minutes - lift the printer upside down and shake it sideways (strange huh?... usually, this helps because it can re-align those things that may not be aligned right inside the printer) - then, adjust the paper guides and use about 10-15 pieces of paper. try using the printer. if it's still the same... it really is the printer. - if it's still under warranty, Dell can replace it. This information is from Dell, try it it can't hurt.
Posted on Mar 26, 2008
Scott Ellin
  • 558 Answers
SOURCE: Paper Jam
Open the tray and cover. Look out for any paper inside the cover.
Close the cover and tray firmly. Then check for a test page.
Let me know if I can assist you further. Don't forget to vote the solution.
Regards
Ellin
Posted on Sep 26, 2008
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
Nov 23, 2015 | Brother Office Equipment & Supplies
My lexmark inkjet printer model p4350 requests to clear paper jam. How can i clear it when i still cant identify a paper stuck inside the printer
Hi
If you cannot see any paper inside the most likely cause is the microswitch that detects a jam has stuck in the on postion or there is a small bit of paper stuck on it look for the switch and un jam or remove the small bit of paper on it
Cliff Cook
Aug 03, 2014 | Office Equipment & Supplies
How do I clear a paper jam in my Sharp EL-2630PIII adding machine?
My paper is stuck and jammed in the feeder. I cant add new paper because of the jam. The new paper crinkles up as it feeds. Is there a way to remove the jam of paper that's stuck inside ?
Jun 13, 2014 | Sharp EL-2630P Calculator
Have a paper jam in my pixma ip4500 and cant see the paper anywher to take it out?
Paper jam I suppose is the commonest of all printer problems as it can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation.
Follow the given steps to clear paper jam
>Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Mar 15, 2013 | Office Equipment & Supplies
We have a paper jam according to the display but have found small pieces of paper tucked away but cant find any more is there a reset or is there somewhere more may be that we cant see/get to?
If your machine is detecting a jam with no obvious signs of paper, you most likely have small amounts of debris or dirt blocking the jam sensor. I suggest manually feeding a piece of thick card stock through the paper path, then spray the path with some canned air, as this will act to clear any dirt blocking the jam sensor.
-David.
Nov 03, 2010 | Samsung SF-340 Plain Paper Inkjet Fax
Paper jam
OK, you will need to preform a hard reset. unplug the unit for 5 min.
Mar 04, 2009 | OKI B4300 Led Printer
Paper jam
It's pretty rare to not be able to manually clear a paper jam. Occasionally, after you clear a jam, some paper gets stuck in the mechanism where your fingers can't reach. In that case, part of the printer mechanism needs to be taken apart to get to the jam. Like I said, it's pretty rare, but when it happens, your only option is to take the printer to a certified printer repair shop or back to the place where you bought it to get it worked on. Unless you know what you're doing, I wouldn't recommend using tools inside the printer yourself. You run the risk of damaging the mechanism and making your current problem worse.
The HP web site does publish a couple of solutions. Have a look at the information on the following two links and see if there's anything you may not have tried yet:
Clearing a Paper Jam
Clearing a Carriage Jam
Post back whether or not either of these links worked out for you. Good luck.
Oct 01, 2008 | HP PSC 1610 All-In-One InkJet Printer
I cant recive any fax
Sometimes the plain paper in the tray underneath upsets the whole machine.
Open up the top of the machine, as if you were going to change the toner cartridge. Pull out the cartridge carefully to mae sure that there is not a piece of paper jameed underneath. Replace the catridge and close the top of the machine. when you close the top 'door' the machine will make a noise as if it is resetting itself - the 'jam' display may or may not clear at this point. Next, pull out the paper tray. You will need to stoop down to look into the gap where the tray normally sits. If there is a piece of paper jammed at the back this will need to be carefully removed. If you pull it out make sure there a re no fragments left int he machine - you can check this by oepning out the piece of paper removed and see if there are any pieces missing.
Finally, if all is clear, replace the paper tray (it would be worth topping up your supply of paper as the 'jam' message sometimes comes up when the machine has a low paper supply.
Hope this helps.
Sep 08, 2008 | Canon FAX-L350 Plain Paper Laser
Dell C1765nf Multifunction Color Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
