Question about Roper RAS6233KQ Top Load Washer
The water pump is leaking and I need to take it off but can't figure out how. Can you tell me. The model # is RAX6144EW
I hope this information may help.
copy n paste
http://www.partselect.com/MultiModels.aspx?ModelNum=RAS6233KQ&searchTerm=img_FOU23FEA&RefineSearch=0&imgMfg=Whirlpool&Page=4
1) Unplugged electrical cord
2) Removed hot/cold water hoses
3) Took drain hose from laundry room recepatcle
4) Moved washing machine to area where I could lay it down on its back (very important for easy fix)
5) Found (easy accessible in my case) water pump with an inlet and outlet water hose held on with spring clamps.
6) Removed each of the two clamps with pliers and each hose by twisting loose
7) Remove two metal clips holding pump to motor housing
8) Slide pump off shaft - removal is finished!
9) Reversed process for installation, making sure to gently align pump housing when the pump is aligned with the shaft
[probably took less than 15 minutes
"Was this helpful?" YOUR RATEING is very important.thank you
Posted on May 08, 2009
Go to youtube.com, watch the video, it'll show you better than I can tell you.
Here's the URL:
< https://www.youtube.com/watch?v=E17REmqPIDs >
Posted on Jul 22, 2015
Hi, I can help. The best way is to remove the cabinet. To do this, you need to remove the two screws that hold the control panel to the top of the machine. The screws are located on each end. Then you need to lift the control panel and it will rest on the hinges. Now you need to locate the clamps that lock the cabinet to the frame. These clamps are a copper color and located on the left and right edge. Unplug the quick connect for the lid switch and pull the cabinet toward you. The cabinet will lift off the fram. Now you will have easy access to the pump.
If you need more help, Please let me know
Vic
Apr 05, 2013 | GE 24 in. Profile PDW7800 Built-in...
Oct 18, 2012 | Cars & Trucks
Mar 11, 2011 | Geo Storm Cars & Trucks
Dec 14, 2010 | Oldsmobile Achieva Cars & Trucks
Apr 13, 2010 | 1997 Dodge Grand Caravan
Nov 17, 2009 | 1988 Honda CBR 400
Oct 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Sep 21, 2009 | 1995 Toyota Camry
Oct 21, 2008 | 1994 Buick Roadmaster
181 people viewed this question
