Question about Mitsubishi WS-65611 65" Rear Projection Television
Mitsubishi WS-65611 losing HD signal
I hope someone can help with this problem.  My WS-65611 has always been a great TV, but lately it think it's losing sync on tv programs, either live or recorded, on my DirecTV Hi-Def dvr.  If I switch the input to one of the 480i inputs, it works ok, so it's not the box or cables.  The screen goes black & audio stops, and none of the remotes work.  When it comes back, there's a message saying there was a power outage or a connection is wrong.  Sometimes, the audio goes all the way up, sometimes it goes down.  The reason I think sync might be involved is that when I put up the device menu (if the buttons happen to be working), the audio & video come back.  I was thinking that was caused by the menu providing the sync for the picture. I just can't stand it flashing on & off, sometimes screwing up for hours, sometimes perfect for days at a time.  If I had to guess based on the intermittant nature of the problem, I'd say something is loose, probably the input for the green component cable that carries the sync.  But it'll cost me about $100 for a housecall by a repairman, and another $85 for an estimate, before they even fix the darn thing.  Is it worth fixing?  Is the whole thing ready to go belly-up?  Please keep whatever answer you can come up with in layman's terms, because I obviously don't know what I'm talking about.
  • 1 more comment
  • tgiannazzo Oct 12, 2007
    Sorry, but I don't understand what you're trying to tell me. It has an integrated HD receiver, but I want more HD than I can get with an off-air antenna.  I'm hooked up to a DirecTV HD Digital Video Recorder.
  • tgiannazzo Oct 13, 2007
    The TV loses either power or the signal periodically.  It goes to black, audio stops, remotes don't work. When it comes back after a few seconds, audio is higher or lower. Sometimes the remotes work, sometimes they don't. This only happens on the 1080i input from the DirecTV Tivo, either live or recorded.
  • 790 Answers
Ok please tell me your main problem! in short!
Posted on Oct 13, 2007
  • carlos fernandez Jr.
    carlos fernandez Jr. Oct 14, 2007
    ok the problem is the tv right! base in your complaint the system is in
    abnormally function! my customer  in my repair center is the same
    problem! ok all you have to do is to change all tact switches in the
    main tv panel switches! thats why your TV is in abnormal system
    function!. your tact switch is now have resistance thats why your TV
    automatically on and off sometimes changing channels and volume control!
  • 4,889 Answers
Not to worry.Its really a Great tv...But...the only thing you should do to fix this just get it hd ready and your and dont get it integrated with an hd receiver and everything will be fine!
Posted on Oct 11, 2007
SOURCE:
Ws 65611 will not play HD channels. Screen gets fuzzy like it is trying to focus, then converts to blue screen that states "Check connections or power. The connections for RGBHV or YPrPb invalid" I have...
This model only has one HD input---it has two sets of component inputs on the back and one is marked 480/1080----in the menu it will be the DTV input.
Check to make sure you are not connected to the other component input.
Let me know what happens and let me know exactly where you are connected and what are using for signal.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Sep 28, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65611 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65611 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65611 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
My ws-65611 always stay in 480i even with HD signal.
If you are using the component connection, make sure you are connected to the one that will support 1080i. If that is not the problem, make sure that the HD receiver is outputting 1080i and not 720p. No RPCRT will support 720p and the video may be down-rezed to 480 since this is the case.
Jan 25, 2009 | Mitsubishi WS-65611 65" Rear Projection...
My Mitsubishi WS-65611 will not turn on
comes on and goes right back off, no pic or sound
May 24, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Download Mitsubishi WS-65611 HDTV Manual
Have you misplaced your Mitsubishi WS-65611 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65611 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Tip
I hope that helps.
on May 04, 2010 | Televison & Video
Mitsubishi WS-65611 Blinking lights.
You are probably talking about the FMT board. I think you can have this board repaired at PTS 18008447871
Mar 13, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Tip
I hope that helps.
Tip
I hope that helps.
Mitsubishi WS-65611 65" Rear Projection Television Logo
112 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
