Question about Sony Ericsson Walkman W810i Cellular Phone
Security lock i want to know that is there any function that i can use a security code after keypad lock so that no one can enter in my phone
  • swapya Aug 22, 2008
    i want a security for my w810i mobile keypad; so that no one can see my phone without mu permission
Yes there is, there should be a phone lock that should have a time limit attached to it.  this is usually found in the phone settings menu.  then you can change this and set a code and a time limit for it to become operational by.
Posted on Oct 15, 2007
SOURCE:
I forgot my samsung cell phone keypad and now i dont know how to unlock it??
Hi Friends,
Press the menu button and * you phone keypad is open. the mention instruction how to use phone keypad lock.
  1. From the standby screen, press Menu
  2. Press Settings
  3. Press Phone
  4. Press Security
  5. From the Lock Phone section press one of the folllowing:
    • On- The phone locks immediately and stays locked until you enter the correct lock code
    • Off- The phone remains unlocked
Sep 03, 2011 | Samsung Cell Phones
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
I want your phone locker?
You can set up a security code to lock your Nokia 6288 keypad in case a thief tries to call from your stolen phone
Published on Mar 14, 2007
You can set up a security code to lock your Nokia 6280's keypad in case your phone opens in your pocket and calls one of your contacts, annoying them and potentially running up a huge bill.
The code will also stop a thief from using your stolen Nokia 6280 to run up a huge phone bill before you can alert your network provider.
To set the security code, click Menu > Settings > Phone > Security keyguard. You'll be prompted for the Security code. By default this is 12345. Enter this and press OK. Select On and click Select to see the message 'Security keyguard activated'.
Now when you slide your phone shut and press Lock, you'll see the message 'Keypad locked with security code'.
When you slide it open, you'll be prompted to enter the security code. Type your code and click OK to activate your keypad.
Of course, if any potential phone thieves are reading this, they'll now know the default security code is 12345.
To change the security code, go to Menu > Settings > Security > Access codes > Change security code. When prompted, enter your current security code and click OK. The enter your new security code (a PIN between 5 and 10 digits in length), click OK and enter the new code again to verify it. Click OK and you'll see the message 'Security code changed'.
Hope this helps.
Jan 12, 2011 | Nokia Lands Phones
Mobile model:1662-2 I have put security code for keypad lock.but my friend enter wrong code for 5-6 times.now i can't access it even entering right code.what to do.my keypad is locked.
Hi I want to put the security code to my cell b'coz some body miss used my cell but i don't how is it can you help. i don't know the procedure?
Dec 20, 2010 | Nokia 3110 Cellular Phone
Hello sir/madam i would like to know regarding my nokia 5310 express music phone is there any option to lock my phone. kindly do the needful at the earliest with warm regards nazia
Hi Nazia,
I guess you want to lock you phone so that others should not be able to use it without your permission. If this is correct you can perform the following steps:
Open > Settings > Security > Security Level > select Phone, Enter default code "12345" , Click back, Select Access codes, Select change security code, Enter the default code, You will be prompted to Enter new security code, Select the code of your choice, That's it You are all set
When you phone's keypad is locked no-one can open it without putting the correct security code.
Hope you find this useful.
Thank you for using Fixya
Oct 08, 2009 | Nokia 5310 Cellular Phone
Forgot my keypad lock code and when i try to enter the master
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Sep 15, 2009 | Nokia 1600 Cellular Phone
The keypad on my nokia 5310 will not lock even though keypad lock is switched on
To unlock the keypad, select Unlock, and press * within
1.5 seconds. If Security keyguard is set to on, enter
the security code if requested.
To answer a call when the keypad is locked, press the
call key. When you end or reject the call, the keypad
automatically locks
Aug 30, 2009 | Nokia 5310 Cellular Phone
Nokia 1100
Try this:
Go into security settings/change security code/
-default code is usually 12345
-enter new code and repeat
go into keypad auto lock
-input yes
go into phone auto lock period
-input time(e.g 10seconds)
Now when you are out on the main menu,after 10s it should automatically lock.
When your sim card is removed or when you turn your fone on it will ask for the security code.
hope this helps
Apr 30, 2009 | Nokia 1100
Keypad lock w580i
To set the security code for your phone,
from Standby select:
1. Menu--> Settings--> General tab--> Security--> Locks--> Phone protection--> Protection
2. Select an alternative
3. Enter the Phone lock code and click OK
To unlock your cell phone,
Enter the phone code and click OK
Jan 04, 2009 | Sony Ericsson w580i Cellular Phone
How to lock the keypad with security code for sony ericsson?
I DONT WANT THE AUTOMATIC KEYPAD LOCK..BUT I WANT TO KNOW HOW TO MAKE KEYPAD SECURITY CODE SAME AS NOKIA..PLEASE HELP ME..
Dec 26, 2008 | Sony Ericsson S710a
Sony Ericsson Walkman W810i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
