Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG washer WM2016CW loose drum - LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
  • 489 Answers
SOURCE: LG WM2016CW front load washer
Check to make sure that the filters in the water valves are not clogged up.  Go behind the machine, turn off the water supply and disconnect the hoses on the machine side.  Look inside the water valves and check the filter screens to make sure they're clean.  Get a large bucket and open the water valve to clear out the hoses and make sure you have good water flow coming out of the hoses.  If both of those situations are cleared up, your machine should work properly.
Posted on Sep 29, 2008
SOURCE: The lights on my LG WM2016CW will not come on.
While looking for the fuse, which I could not find despite opening up the machine from the back (and vacuuming underneath--yuck!), I left the washer unplugged for about 30 min. From reading other forums and such, I realized that unplugging for a little while is often the solution because the prolonged (at least 5 min) lack of power triggers the system to reset. Sure enough, when I went back to plug it in and give up for the night, the thing worked fine. Good luck to anyone else out there!
Posted on Aug 24, 2009
SOURCE: I have a LG WM2016CW washing machine and there is
You said "stuck" in the drum somewhere? Like under the agitator vanes? You should be able to take the lid off the agitator, it should either clip in or have a screw holding it on, and there you will see the nut, or keeper that holds the agitator on the motor shaft. Remove that clip or nut and you can lift the agitator out of the washer. From there you will see all of the wash drum and should be able to remove any foreign objects. If these "coins" are between the inner and outer tub, then you will have to remove both the top cover and lid, and remove the agitator and the inner drum to get to the outer drum in order to reach these objects. Not a hard job, but it will take you a little while. You could try reaching with your fingers around the agitator bottom and see if you can "feel" the coins or objects and possible use a small brush or stick or popsicle stick to move them out so that you can reach them, Kinda like "fishing" under the refrigerator or the couch. In the alternative, you could enlist four friends and unhook the washer from the water supply and the electric, and turn it upside down and try to shake the coins or objects out the top of the drum. Tilting the machine to one side will let them fall to the cabinet sides and possibly drop out the bottom when it is uprighted. Now I know why Mom always "checked" my pockets before she washed Dad and my clothes. We left a little of everything in there, from time to time. Good Luck with this.
Posted on Sep 27, 2009
SOURCE: LG Model WM2016CW Front load washer is 1 year old.
Same thing happened to me
I freaked out
Then I emptied the water basin, on the front of the machine near the bottom. then it started up and worked
Posted on Aug 17, 2010
pctech1
  • 1940 Answers
SOURCE: my washer won,t drain how hard is it to replace
Open the little door in the bottom left hand corner, unscrew the black cap and drain the water out.
If this doesn't fix the problem, you may need a new Drain pump. Unplug the machine. Remove the filter recess by removing the one screw inside and using a putty knife at the left and / or right edge and popping it out. Pull the machine out about 18 inches and tip it back, resting it against the wall. Remove two more screws behind where the recess was holding the pump housing on. Reach under the machine and remove pump. There is a tab to depress under the pump housing to release it from the base. The pump motor is held onto the housing by three screws. Remove them and inspect the impeller to see if it has come off the shaft. If it has, pushing it back on will not solve the problem, as it will come off again. Install new drain pump and reassemble.
Posted on Feb 27, 2011
How do I fix a loose or locked up drum that generates LE errors?
you sure it is not and upside down 'F' instead of an L? that would be a hall sensor(motor position sensor) error. easy fix. check out appliancepartspros.com or repairclinic.com for both parts and videos that show how to repair. very easy with common tools. about 20-30 minutes. basically take back cover off, remove motor cover, remove stator, replace part.
Aug 30, 2015 | LG WM2016CW Front Load Washer
My LG washer is not draining, I have OE code. Is there way to test the drain pump with out having to fill the drum/washer with water?
Hi if you remove the pump again get a plug and wires example from a table lamp and attach 2 wires to the pump dont worry about polarity it will run both ways plug into the wall see if the pump runs out of the machine ( does this model have 2 pumps one could be the recirculation pump)
Dec 27, 2014 | LG WM2016CW Front Load Washer
How do you fix the rear tub spindle on an lg wm2016cw?
If its the main drum bearings gone then this will entail a complete strip to access them. The parts are available online, just have your serial no, model etc ready and trawl through various web appliance sites to find the best price. You will need a fair amount of mechanical / DIY knowledge to carry out this task. There are lots of parts and electrical connections.
Aug 05, 2014 | LG WM2016CW Front Load Washer
What are the most major issues with lg wm2016cw washers?
all washing machines suffer from same things.overloading throws balance off stuff in pockets finds its way to the pump too much powder is used causing blockages and soft water areas cause elements to fir up with limescale.eventally motor brushes wear.but theyre cheap to replace
Aug 05, 2014 | LG WM2010C Front Load Stacked Washer /...
How to restart?
normally pressing and holding start or stop will reset .removing drain hose from wall and holding at ground level will empty all washing machines.so have it in a bucket.either its not level so adjust feet so it cant rock about then dont overload it turn drum as u load that will help balance.
Jul 28, 2014 | LG WM2016CW Front Load Washer
Wm2016cw
LE errors mean the motor is locking up and cannot turn the drum. If the drum turns freely by hand then it could be https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/406-200-684484-/LG-LE-MOTOR-ERROR-Motor-Stator-overheat-or-connection-error-WM2016CW
If that is not the problem then the motor needs replaced.
Apr 15, 2017 | Washing Machines
Washing Machines Logo
135 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
