Remote Controls
Problem for Remote Controls
Generic problem for all Remote Controls
Technika tt- 706 universal 2 in 1 remote
By Andrwe on Oct 10, 2007
Hi sorry i have just bought this remote fron tesco and have no idea how to set it to my tv as there are no instructions? and i cant find anything on the web for TT-706 Please help
Same Problem
Apr 26, 2009
-   i have just bought the same tt-706 and no instructions either, just flashes when you press the set button and then nothing! has any one any ideas on how this works?-   Guest
Apr 26, 2009
-   i have tried holding tv and set button and waiting for tv to turn off but its not doing anything. does anyone have a copy of manual so i can type sharp tv codes in? -   Guest
Apr 17, 2009
-   does anyone have codes for a sharp tv? lost my book and my son is not happy as i cant change tv over for him to play on the wii
-   Guest
Apr 14, 2009
-   Im throwing mine in the bin! I Have tried everything now!-   Guest
Jan 12, 2009
-   i need the codes for my sharp tv can you plzzzzz help. i have a technika 706 uni remote. -   ali_f1
Best Solution
posted on Feb 13, 2008
Helpful)
prophet880
Rank: Apprentice
Rating: 94%, 16 votes
turn the tv on. hold tv and set buttons untill the power button flashes. point the remot at the tv untill the tv turns its self off. press any button on the remote. turn the tv back on and test it.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Apr 28, 2008
Helpful)
zaphod000001
Rank: Apprentice
Rating: 89%, 9 votes
Method for programming TT-707: press set and TV together - red light comes on. Enter 3 digit code. red light flashes after first 2 digits entered, goes out after 3rd. press power to test. repeat with another code if necessary.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Aug 22, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I realized the solution, press it the set button, keep it pushed and nyomde shortly the TV, you are DvB button.now it on/off a button glitters, write the suitable code in and works already.
Solution #4
posted on Nov 09, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
for tv setting. Press TV. then press set and hold at same time hold tv (wait 3 seconds.) the hand set cycles all codes, when it turns off the TV press a button (but not set) turn on TV and test controller... Repeat to get better settings
Solution #5
posted on May 08, 2008
Not Helpful)
munter
Rank: Apprentice
Rating: 45%, 4 votes
I had the same problem - and ended up buying another remote, just to get the manual.
To save everyone else from having to the same, I've scanned it and put it here,
http://www.****.ukpc.net/tt706/
(it's a bit of a scruffy scan, but should print onto A4 fairly readably)
Comments:
May 08, 2008
- The address for my scans seems to be displaying strangely.
The four asterisks should read "****" , without the quotes
Was this helpful?
Yes
No
Solution #6
posted on Oct 06, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
throw it out the window!!! tryed everything and it just will not work.
Solution #7
posted on Jul 07, 2009
Somewhat Helpful)
adamout
Rank: Apprentice
Rating: 75%, 1 votes
The instructions are useless!!
Simply hold the SET button, press the TV or DVD button down.
Now release both.
The red light will stay on
Type in your code (it will flash with every digit pressed but do nothing at the end to signal a correct code)
Try some buttons to see if the code works
My TV only worked with the last one listed so keep trying.
Hope this helps
Was this helpful?
Yes
No
Solution #8
posted on Aug 25, 2009
Not Rated)
bird_winner
Rank: Apprentice
Rating: 0%, 0 votes
hello, is there a way set the channel and volume button to work, cos i can only control the channels by pressing numbers and can't control the volume at all!???
Was this helpful?
Yes
No
Solution #9
posted on Jan 20, 2009
Not Rated)
daz4518
Rank: Apprentice
Rating: 0%, 0 votes
press and hold the button you want it tuned to eg: tv or DVB the set until one of the buttons start flahin, cant remember what it is though, but it flashes, whilst it is doing this you have to have it pointing to your tv etc until it goes into standby, once it has done this press any button on the remote apart from stand by, set or the button labelled tv or dvbor whatever you are using, so just use ok or enter and that should be it
Was this helpful?
Yes
No
Popular Solutions for Remote Controls
Questions and Unsolved Problems for Remote Controls
Answer
How do I determine the code for my emerson fan remote control?
Answer
What universal remote should I buy to operate my Hitachi Model # CT-7894BC. I have two IR on my... (More)
Answer
bought new emerson cl32emxftv cant get mt dish net remotr to scan it in does any one khow the... (More)
Answer
cannot program my yamaha receiver pwr on and off. tried all codes supplied by yamaha. using a new... (More)
Answer
remote works sometimes. tink it need battery. don't want to break it--but DO want to open it up.
17 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 03, 2009
no instrucions dont no how to use it plz help
Comment by Guest, posted on Dec 12, 2008
ja was nie rozumiem moå¼ecie normalnie podaä† stronä™, tzn. bez gwiazdek. Abo coå› podobnego gdzie moå¼na uzyskaä† kody do tego stupid pilota:>
I have a Technika television and a Tecknika TT-707 universal remote. The remote manual doesn't have any technika remote codes. what a load of ****.
Comment by Mick Jagger, posted on Dec 09, 2008
Tried the auto way, now my Ferguson TV flashes redon standby and I can't turn back on..If anyone has the Ferguson code i'll try again...
Comment by Guest, posted on Dec 07, 2008
me to
Comment by danny1690, posted on Oct 20, 2008
got the remote from tesco and a dont know how to set up a need a code for a sony
Comment by gmacartney, posted on Aug 11, 2008
bought from tesco no instuctions rubbish
Comment by Guest, posted on Jun 15, 2008
again no instructions given from Tesco with this model - can only get power to turn on/off on one portable tv - but not the Toshiba 14"
Comment by Guest, posted on May 31, 2008
I've tried all suggested methods, including manual code-entry with no success.
Comment by OhMyx, posted on Mar 26, 2008
I have done the steps as described and the television turns off, however, when I turn it back on the remote does not respond. ANy suggestions?
Comment by slothgimp, posted on Mar 18, 2008
I have the same remote which I want to use for a technika tv/dvb/dvd player but the instructions do not come with any codes for any technika product!
I've tried to scan manually and automaticly but it still doesn't have it. Any ideas?
Comment by xclairex, posted on Dec 13, 2007
iv pressed tv then i pressed set and tv together for three seconds but nothings working please help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Remote Controls:
Top Remote Control Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Remote Control Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
