Question about Frigidaire 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black
Refrigerator display changing
Do not know what the dia should be is 1 lowest and the up?
How to thaw a 20 lb turkery in refigeratores
Would need to know a bit more information.
1 Type of refrigerator (top freezer or side by side or bottom freezer)
2 How soon do you need turkey thawed
On 1
Top freezer type = place turkey on lowest shelve in a pan to catch water.
On Side by Side type = this will take the longest to thaw as it has a consistent temp through out.
On bottom freezer type - place turkey on highest shelf of refrigerator.
Nov 21, 2013 | Refrigerators
Where is the A/C drain hose on a 06 caddy
At the lowest point of the a/c box and drains out through the firewall behind the engine Check underneath and look for a plastic hose about 1/2 to 5/8 in dia and that will give you an indication of where to look inside the car. You will have to pull the floor carpet back from under the a/c box to see it
Feb 06, 2013 | Cars & Trucks
Kenmore refrigerator control box temp. keeps changing by itself
Your most likely cause is the $170 control board. It is the only thing that I know of that can change the temperature automatically. Please rate this post.
Dec 14, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Regrigerator water pipe is broken
refrig's only use 5/16 or 1/4" dia. lines. you can cut and splice the broken line if you can find a 5/16" X 5/16" quick disconnect coupler. homedepot only carries 1/4'. try your local plumbing store.
Jul 14, 2009 | Refrigerators
How to change the thermostat on a Hotpoint RLA30 fridge
It is behind the knob your are adjusting to change the temperature.
It is very easy for me. Don't know how easy for you and your electrician friend.
Apr 20, 2009 | Hotpoint RLA30 Compact Refrigerator
Produce freezing
I had the same problem when one of my kids changed the setting of the chef's pantry (full-width drawer) to higher setting and everything started freezing. The setting should be at "lowest setting". Give it a try. deborah.
Feb 07, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Frigidaire 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black Logo
16 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
