Question about Cooktops
Dacor cooktop My Dacor Part Number EM4LFB is cracked. I need to find one. They have been discontinued. It's a module of two electric burners in black and it drops in and plugs into Dacor Cooktop Black Electric Model # ECC36B. Do you have any suggestions? Thanks.
  • 338 Answers
SOURCE: Broken glass for 5 burners electric Bosch cooktop
If you can give me the model number I can give you 3 places and there prices. The model number should be located on the bottom of the unit.
Posted on Dec 04, 2008
  • 10865 Answers
SOURCE: how to clean glass cooktop maytag electric Model
Hello. Maytag has a special cleaning cream just for their glass cooktop. You can get it whereever the stoves are sold or at this link http://www.buzzillions.com/reviews/maytag-cooktop-cleaning-creme-smooth-top-ranges-reviews
Joe
Posted on May 07, 2010
tunde007
  • 2382 Answers
SOURCE: The dual element on my electric smooth-glass
Hi, my humble advice to you is to call in the repair man to come and carry out a check and properly diagnose what the problem is.
You might be lucky to have a fuse problem which th repair man will find and replace it and if the element goes beyond the fuse issue, the repair man will be in the best position to determine if you are to purchase and install a burner module or buying a new cooktop...
So call in the repairman first.....
Posted on Sep 19, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: I have a Dacor electric
Sorry to read about your problem, I hope this helps you out.
you might want a new unit, glass replacement will cost from $600.00 to $900.00 and thats just for the glass
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 21, 2010
espressonist
  • 1711 Answers
SOURCE: Replacement solid elememt burner unit for my Dacor ECC46 electric cooktop
Have you try this link
Posted on Apr 06, 2012
My Dacor PGM365-01 main burner continues to spark after I place a pot or pan over it. I just replaced the spark module - still happening. Valve? Micro-switch? Clean the burner?
What is your altitude?I have the same problem and was told by Dacor that I should have the high altitude version. I'm at 5000'
Feb 14, 2015 | Dacor Cooktops
Igniters won't stop Dacor Preference SGM466 Gas Cooktop. Tried cleaning and want to remove the burners. What is the correct way to do so?
Problem is the insulation on the spark wires is dried and cracked. I bet you can hear the sparking coming from inside the unit, rather than where you see the spark, correct? The excess voltage is grounding inside, rather than thru the flame. I believe you pull the burners off and tap those brass rings with a screwdriver/hammer (or buy the correct tool). Then you can lift the entire top off.
Feb 08, 2011 | Dacor Preference SGM466 Gas Cooktop
I have a Dacor electric ceran topped cooktop, model ECC46S. One of the ceran glass tops is cracked badly. I have searched everywhere for either a complete module, EM4LFB with no results. I probably...
Dec 20, 2010 | Dacor Cooktops
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
Dacor 46 inch 6 burner cooktop
The cost of the parts you want t o replace will usually exceed the price of a new cooktop.
Jun 08, 2008 | Dacor Preference SGM466 Gas Cooktop
Dacor ignitor keeps clicking
Dacor has updated ignitors with a broad head. Install the new ones and it will very likely cure the problem. You'll need a special spanner wrench to remove the burners. And watch out for the flying keeper clips.
Oct 06, 2007 | Dacor Preference SGM365SS Gas Cooktop
Dacor Cooktop gas conversion
Where did you purchase the kit? Can you name the store with number or list the website? Also the part number information. Thanks
Sep 19, 2007 | Dacor Preference SGM365SS Gas Cooktop
Oven Striker
If I'm not mistaken, these dacor cooktops have an automatic re-ignition (meaning if the flame goes out, it will just relight it without you having to do it) If none of your burners will light, you probably have a bad spark ignition module. These are somewhat hard to change, as you have to take all the burners off and disconnect the spark wires and take the whole top of the cooktop off to get to the inner workings. Also, to get these burner bases off it takes a special tool by dacor, AND you usually have to replace all the burner seals once you take them apart.Your other, simpler option is to unplug the cooktop and plug a lamp or something in to the outlet the cooktop is using, just to make sure you have power. Just cause the breaker doesn't look like it's tripped, doesn't mean it isn't bad and the outlet is dead. Hope this helps!
Oct 12, 2006 | Dacor Preference SGM466SS Gas Cooktop
Cooktops Logo
90 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
